17 AT SHIFT FORK
1 21214RWE000 PLATE, OIL SEPARATE
2 24000RWEA00 SHAFT ASSY., CHANGE CONTROL
3 24111RYF000 FORK, REVERSE SHIFT
4 24282634000 BOLT, SHAFT FORK SETTING
5 24552RDK000 SPRING, PARKING BRAKE PAWL
6 24561RDH000 PAWL, PARKING BRAKE
7 24562RDKA00 SHAFT, PARKING
8 24630R36000 ARM, CHANGE DETENT
9 24634PRP060 SPRING, DETENT LEVER
10 24635RDK000 SHAFT, CHANGE DETENT ARM
11 25420RWE014 STRAINER ASSY. (ATF)
12 90001RDK000 BOLT, FLANGE (6X80)
13 90433639000 WASHER, LOCK (6MM)
14 90701RDK000 PIN, DOWEL (8X73)
15 91301RCT004 O-RING (21.8X1.9)
16 957010603008 BOLT, FLANGE (6X30)
17 958010609508 BOLT, FLANGE (6X95)
