14 AT REGULATOR BODY
1 24271RWE000 SHAFT, SHIFT FORK
2 25155RWE000 SHAFT ASSY., STATOR
3 27142P6H000 CAP (15MM)
4 27200R36A00 BODY ASSY., REGULATOR
5 27212RJBE00 PLATE, REGULATOR SEPARATING
6 27246RDK000 CAP, REGULATOR SPRING
7 27430RPC003 BOLT, AIR CHECK
8 27524P6H000 CLIP, CAP
9 27561PAX000 PISTON, LOW ACCUMULATOR
10 27583RDK000 SPRING, THIRD ACCUMULATOR
11 27592RJB000 COVER, ACCUMULATOR
12 90001PRP000 BOLT, FLANGE (6X30)
13 90024612000 BOLT, SEALING (8MM)
14 90089PK4000 BOLT, STOPPER (6MM)
15 90471580000 GASKET (8MM)
16 90472RPC000 GASKET (10MM)
17 90702RDK000 PIN, DOWEL (7X71)
18 91316PY4003 O-RING (32.5X1.8) (ARAI)
19 91331PC9003 O-RING (21.2X2.4) (ARAI)
20 91344580000 O-RING (31X2.7) (ARAI)
21 9430108140 PIN, DOWEL (8X14)
22 957010603508 BOLT, FLANGE (6X35)
23 957010607008 BOLT, FLANGE (6X70)
24 957010609008 BOLT, FLANGE (6X90)
