11 PARKING BRAKE
1 46911S70003 PIN, LOCK (8MM)
2 47100TX4A82 PEDAL ASSY., FOOT PARKING BRAKE
3 47110TX0A81 BRACKET SET, HARNESS GURAD
4 47120T0AA01 PAD, PEDAL
5 47153S2A000 PIN, HAND BRAKE
6 47210TX4A82 WIRE A, PARKING BRAKE
7 47342SFJW81 SWITCH, PARKING BRAKE
8 47344TR0A01 SCREW, TAPPING (4X10)
9 47360SB2000 EQUALIZER
10 47365S6AN00 PIN, EQUALIZER
11 47510TX4A01 WIRE B, R. PARKING BRAKE
12 47522594000 NUT, PARKING BRAKE ADJUSTING
13 47560TX4A01 WIRE B, L. PARKING BRAKE
14 47572S9A000 BASE, WIRE GUIDE
15 47574TX4A80 SPRING, RETURN
16 47577TX4A00 GUARD, BRAKE WIRE
17 90361SV4003 NUT, PAINT CUTTING (6MM)
18 91560SFA003 CLIP, SRS BRACKET
19 934020501008 BOLT-WASHER (5X10)
20 934030801608 BOLT-WASHER (8X16)
21 94001080000S NUT, HEX. (8MM)
22 9405008080 NUT, FLANGE (8MM)
23 957010601608 BOLT, FLANGE (6X16)
24 957010801608 BOLT, FLANGE (8X16)
25 957010802008 BOLT, FLANGE (8X20)
26 957010804008 BOLT, FLANGE (8X40)
