11 AT ATF PIPE
1 21516RWE000 STAY, TEMPERATURE SENSOR CONNECTOR (ATF)
3 25450P4V013 FILTER
4 25471RJB000 COVER, ELEMENT
5 25475RJFT00 PIPE, RETURN (ATF)
6 25610RWE013 DIPSTICK (ATF)
7 25613RWE000 PIPE, DIPSTICK (ATF)
8 25910RWE000 PIPE A (ATF)
9 25920RWE000 PIPE B (ATF)
10 25951RGR000 BOLT, JOINT
11 28900RYF023 SENSOR ASSY., POSITION
12 28921P5H003 NUT, HEX. SPECIAL (16MM)
13 28922RJB003 WASHER, LOCK (16MM)
15 32745RWCA00 STAY L, ENGINE HARNESS
16 32746RWCA00 STAY W, ENGINE HARNESS
17 54313STKA81 LEVER, CONTROL
18 54314SDAA81 PIN, CONTROL WIRE
19 90002RDK000 NUT, HEX. (8MM)
20 90439RDK000 WASHER, LOCK (8MM)
21 90471RGR000 WASHER, DRAIN PLUG (12MM)
22 90715SDA000 PIN, SNAP (8MM)
23 91209612003 OIL SEAL (12X22X7) (ARAI)
24 91305PN4003 O-RING (37.7X3.5) (ARAI)
25 91314PC9004 O-RING (8.5X1.9) (NOK)
27 934030602508 BOLT-WASHER (6X25)
28 9411108800 WASHER, SPRING (8MM)
29 957010601208 BOLT, FLANGE (6X12)
30 957010601408 BOLT, FLANGE (6X14)
31 957010602008 BOLT, FLANGE (6X20)
