09 AT SECONDARY SHAFT
1 22814PRP003 RING, SEALING (29MM)
2 23230RWE010 SHAFT, SECONDARY
3 23411RWE000 GEAR, SECONDARY SHAFT LOW
4 23418RJBE00 HUB, CLUTCH (L-H)
5 23420RJFT04 HUB, SECONDARY SHAFT LOW CLUTCH
6 23430RWE000 GEAR, SECONDARY SHAFT SECOND
7 23495RWE000 GEAR, SECONDARY SHAFT IDLE
8 90201RDK000 NUT, FLANGE (26MM)
9 90402RDK000 WASHER (29X40X3.9)
10 90405RJB000 WASHER, THRUST (39X66X9.7)
11 90443RJB000 COLLAR (32X39X63.3)
12 90502RJFT00 WASHER A (52MM) (2.705)
12 90503RJFT00 WASHER B (52MM) (2.680)
12 90504RJFT00 WASHER C (52MM) (2.655)
12 90505RJFT00 WASHER D (52MM) (2.630)
12 90506RJFT00 WASHER E (52MM) (2.605)
12 90507RJFT00 WASHER F (52MM) (2.580)
12 90508RJFT00 WASHER G (52MM) (2.555)
12 90509RJFT00 WASHER H (52MM) (2.530)
12 90510RJFT00 WASHER I (52MM) (2.505)
12 90511RJFT00 WASHER J (52MM) (2.480)
12 90512RJFT00 WASHER K (52MM) (2.455)
12 90513RJFT00 WASHER L (52MM) (2.430)
12 90514RJFT00 WASHER M (52MM) (2.405)
13 90621RDK000 RING, SNAP (32MM)
14 91005RWE003 BEARING, BALL (29X65X9/11)
15 91018RDP003 BEARING, NEEDLE (43.5X59X2.5)
16 91021RJFT01 BEARING, NEEDLE (44X50X22.6)
17 91022RDP003 BEARING, NEEDLE (39X44X47)
18 91032RJB013 NEEDLE, THRUST (44X66X3.5)
19 91039RWE007 NEEDLE, THRUST (46X62.95X4.62)(TIMKEN)
20 91040RDK003 NEEDLE, THRUST (40X57X2.5)
21 91307PA9003 O-RING (31.2X1.9) (ARAI)
22 91326P4V004 O-RING (26.7X1.9) (ARAI)
