08 CANISTER
1 17011STKA01 CANISTER ASSY.
2 17315TP7A01 FILTER, CANISTER
3 17321SDAA01 RETAINER
4 17323STKA01 PROTECTOR
5 17330S9VA01 FILTER, DUST
6 17352STKA00 TUBE A, ATMOSPHERIC
7 17355S9VA01 JOINT, PRESSURE SENSOR
8 17357STKA00 BRACKET, CANISTER FILTER
9 17358STKA00 BRACKET, CANISTER
10 17359SDAA01 BOLT, CANISTER MOUNTING (8MM)
11 17373STKA00 TUBE ASSY., CANISTER DRAIN (B)
12 17374STKA02 TUBE ASSY., CANISTER DRAIN (A)
13 17576STKA00 PIPE, CANISTER GUARD
14 17725STKA02 TUBE, FUEL VENT (ORVR)
16 37940SNAA01 SENSOR, VENT PRESSURE
17 90361SV4003 NUT, PAINT CUTTING (6MM)
18 90671SB2003 BOLT, FR. FENDER
19 91391SDAA01 O-RING
20 91394SDAA01 O-RING
21 91592SJA003 CLAMP, BREATHER TUBE
22 91592S10003 CLIP, DRAIN TUBE (NATURAL)
23 91595SCVA01 CLIP, DRAIN TUBE
24 934050601604 BOLT-WASHER (6X16)
25 934070802004 BOLT-WASHER (8X20)
26 9405008040 NUT, FLANGE (8MM)
27 17742STKA01 JOINT, DRAIN TUBE
