08 AT OIL LEVEL GAUGE - ATF PIPE
1 25212RT4003 HOSE (135MM) (ATF)
2 25430PLR003 FILTER (ATF)
3 25431RT4000 STAY A, FILTER (ATF)
4 25432RT4000 STAY B, FILTER (ATF)
5 25605RT4000 PIPE SUB-ASSY., DIPSTICK (ATF)
6 25610R8B000 DIPSTICK (ATF)
7 25620RT4000 JOINT ASSY., DIPSTICK PIPE (ATF)
8 25910R8B000 PIPE A (ATF)
9 25920RT4000 PIPE B (ATF)
10 25951RGR000 BOLT, JOINT
11 28900RT4003 SENSOR ASSY., POSITION
12 32742RYEA70 STAY B, ENGINE WIRE HARNESS
13 54313TK8A90 LEVER, CONTROL
14 54314SDAA81 PIN, CONTROL WIRE
15 90001PA9000 BOLT, HEX. (6MM)
16 90433P0G000 WASHER, LOCK (6MM)
17 90471RGR000 WASHER, DRAIN PLUG (12MM)
18 90635RV0003 CLIP, OIL PIPE
19 90715SDA000 PIN, SNAP (8MM)
20 91209612003 OIL SEAL (12X22X7) (ARAI)
21 91301P7X003 O-RING (19.20X1.90) (NOK)
22 934030602508 BOLT-WASHER (6X25)
23 957010601208 BOLT, FLANGE (6X12)
24 957010601408 BOLT, FLANGE (6X14)
