08 AT COUNTERSHAFT
1 21215R36000 HOLDER, IDLE SHAFT
2 23221R97000 COUNTERSHAFT
3 23421RWE000 GEAR, COUNTERSHAFT LOW
4 23441RWE000 GEAR, COUNTERSHAFT SECOND
5 23471RDH000 GEAR, COUNTERSHAFT FOURTH
6 23491RYF000 GEAR, COUNTERSHAFT FIFTH
7 23515RWE000 GEAR, COUNTERSHAFT IDLE
8 23531RDK000 GEAR, COUNTERSHAFT REVERSE
9 23541RDK000 GEAR, REVERSE IDLE
10 23565RDK000 SELECTOR, REVERSE GEAR
11 23566RDK000 HUB, SELECTOR
12 90201PRP000 NUT, FLANGE (24MM) (LEFT HAND THREAD)
13 90402P0Z000 WASHER, SPRING (24MM)
14 90404RJBE00 WASHER, THRUST (35X47X3)
15 90408PY4000 WASHER, THRUST (14X30X1)
16 90430RJFT00 COTTER (40.5MM)
17 90431RJFT00 COTTER (42.2MM)
18 90433RJFT00 RETAINER, COTTER
19 90442RDK000 COLLAR (31X40X14.5)
20 90501RJFT00 COLLAR (50.8MM)
21 90519RJFT00 WASHER A (50.8MM) (1.91)
21 90520RJFT00 WASHER B (50.8MM) (1.93)
21 90521RJFT00 WASHER C (50.8MM) (1.95)
21 90522RJFT00 WASHER D (50.8MM) (1.97)
21 90523RJFT00 WASHER E (50.8MM) (1.99)
21 90524RJFT00 WASHER F (50.8MM) (2.01)
21 90525RJFT00 WASHER G (50.8MM) (2.03)
21 90526RJFT00 WASHER H (50.8MM) (2.05)
21 90527RJFT00 WASHER I (50.8MM) (2.07)
21 90528RJFT00 WASHER J (50.8MM) (2.09)
21 90529RJFT00 WASHER K (50.8MM) (2.11)
21 90530RJFT00 WASHER L (50.8MM) (2.13)
21 90531RJFT00 WASHER M (50.8MM) (2.15)
21 90532RJFT00 WASHER N (50.8MM) (2.17)
21 90533RJFT00 WASHER O (50.8MM) (2.19)
21 90534RJFT00 WASHER P (50.8MM) (2.21)
21 90535RJFT00 WASHER Q (50.8MM) (2.23)
21 90536RJFT00 WASHER R (50.8MM) (2.25)
21 90537RJFT00 WASHER S (50.8MM) (2.27)
21 90538RJFT00 WASHER T (50.8MM) (2.29)
21 90539RJFT00 WASHER U (50.8MM) (2.31)
21 90540RJFT00 WASHER V (50.8MM) (2.33)
21 90541RJFT00 WASHER W (50.8MM) (2.35)
21 90542RJFT00 WASHER X (50.8MM) (2.37)
21 90543RJFT00 WASHER Y (50.8MM) (2.39)
21 90544RJFT00 WASHER Z (50.8MM) (2.41)
21 90545RJFT00 WASHER AA (50.8MM) (2.43)
21 90546RJFT00 WASHER AB (50.8MM) (2.45)
22 90582RJFT00 WASHER A (61MM) (1.525)
22 90583RJFT00 WASHER B (61MM) (1.505)
22 90584RJFT00 WASHER C (61MM) (1.485)
22 90585RJFT00 WASHER D (61MM) (1.465)
22 90586RJFT00 WASHER E (61MM) (1.445)
22 90587RJFT00 WASHER F (61MM) (1.425)
22 90588RJFT00 WASHER G (61MM) (1.405)
23 90608RJFT00 CIRCLIP (OUTER) (46MM)
24 90612RJFT00 RING, SNAP (94MM)
25 90615RDK000 RING, SNAP (14MM)
26 91003RWE005 BEARING, BALL (31X94X9.5/21)
27 91020RJFT01 BEARING, NEEDLE (62X70X28.7)
28 91024PAX006 BEARING, NEEDLE (40X46X14.5) (TORRINGTON)
29 91025PJ2003 BEARING, NEEDLE (14X18X15) (NTN)
30 91028RJB003 BEARING, NEEDLE (35X41X28.8)
31 91035RJFT01 NEEDLE, THRUST (70X88.1X4.5)
32 91036RJFT01 NEEDLE, THRUST (61X92.3X5.5)
33 9430110160 PIN, DOWEL (10X16)
34 957010803508 BOLT, FLANGE (8X35)
