07 BRAKE MASTER CYLINDER - MASTER POWER (KA) (KC)
1 01469STKA10 POWER SET, MASTER
2 46100STKA01 MASTER CYLINDER ASSY.
3 46185SHJA01 O-RING
4 46191S2K000 GASKET, MASTER POWER
5 46197SHJA01 NUT-WASHER (8MM)
6 46355STKA01 PIPE, MASTER POWER
7 46401STKA01 SENSOR, MASTER POWER PRESSURE
8 46402STKA04 TUBE ASSY., MASTER POWER
9 46402STKP04 TUBE ASSY., MASTER POWER
10 46409SJA003 CLIP, PIPE (10MM)
11 46409STKA00 BRACKET, MASTER POWER TUBE
12 46460STKA01 PUMP ASSY., VACUUM
14 46466STKA00 BUSH
15 46467STKA00 DAMPER
16 46468STKA00 STAY, MASTER POWER PRESSURE SENSOR
17 46469STKA00 CAP, PROTECTION
18 46512S70000 PIN, PEDAL
19 46662SHJA02 CAP ASSY., RESERVOIR
20 46666SHJA01 STRAINER, MASTER CYLINDER RESERVOIR
21 46674STKA00 BRACKET, RESERVE TANK
22 46911S70003 PIN, LOCK (8MM)
23 53728SDBA01 CLIP, RETURN PIPE
24 91565S0X003 CLIP, CONNECTOR (DARK GREEN)
25 934030601608 BOLT-WASHER (6X16)
26 934040601207 BOLT-WASHER (6X12)
27 934040601608 BOLT-WASHER (6X16)
28 934050601608 BOLT-WASHER (6X16)
29 938920502008 SCREW-WASHER (5X20)
30 9405008080 NUT, FLANGE (8MM)
31 950024073004 CLAMP, TUBE (D7.3)
32 950053500810M BULK HOSE, VACUUM (3.5X8000) OEM CUT SIZE: (3.5X135)
32 950053500810M BULK HOSE, VACUUM (3.5X8000) OEM CUT SIZE: (3.5X95)
33 957010603008 BOLT, FLANGE (6X30)
34 46407STKA01 CLAMP, TUBE
35 46465STKA03 BRACKET, VACUUM PUMP
