05 OUTER PANEL - ROOF PANEL
1 04631STKA00ZZ PANEL, R. SIDE SILL
2 04635STKA00ZZ PANEL SET, R. FR. (OUTER)
3 04636STKA90ZZ PANEL SET, R. RR. (OUTER) (DOT)
4 04641STKA00ZZ PANEL, L. SIDE SILL
5 04645STKA00ZZ PANEL SET, L. FR. (OUTER)
6 04646STKA90ZZ PANEL SET, L. RR. (OUTER) (DOT)
7 62100STKA01ZZ PANEL, ROOF (SUNROOF)
8 63120STKA00ZZ STIFFENER, R. FR. PILLAR (UPPER)
9 63136STKA01 SEPARATOR, FR. PILLAR INSIDE
10 63137STKA01 SEPARATOR, FR. PILLAR (OUTER)
11 63210STKA00ZZ STIFFENER, R. CENTER PILLAR
12 63217STKA01 SEPARATOR, CENTER PILLAR (OUTER)
13 63220STK305ZZ REINFORCEMENT SET, R. SIDE SILL
14 63226STKA01 SEPARATOR, CENTER PILLAR (INSIDE)
16 63320STKA00ZZ GUTTER, R. RR. PILLAR
17 63520STKA00ZZ STIFFENER, L. FR. PILLAR (UPPER)
18 63610STKA00ZZ STIFFENER, L. CENTER PILLAR
19 63620STK305ZZ REINFORCEMENT SET, L. SIDE SILL
20 63720STKA00ZZ GUTTER, L. RR. PILLAR
21 63910STKA00ZZ LID, FUEL FILLER
23 66115STKA01ZZ STIFFENER, R. RR. PANEL SIDE
24 66116STKA00ZZ EXTENSION, R. RR. PANEL SIDE
25 66118SEPA00ZZ STIFFENER, RR. BUMPER FACE
26 66121STKA01ZZ BRACKET, R. RR. BUMPER (LOWER)
27 66123STKA00ZZ BULKHEAD, R. RR. PANEL (B)
28 66124STKA01 SEPARATOR A, R. RR.
29 66125STKA01 SEPARATOR B, R. RR.
30 66165STKA01ZZ STIFFENER, L. RR. PANEL SIDE
31 66166STKA00ZZ EXTENSION, L. RR. PANEL SIDE
32 66171STKA01ZZ BRACKET, L. RR. BUMPER (LOWER)
33 66173STKA00ZZ BULKHEAD, L. RR. PANEL (B)
34 66174STKA01 SEPARATOR A, L. RR.
35 66175STKA01 SEPARATOR B, L. RR.
36 74411STKA01 CABLE, FUEL LID OPENER
37 74480STKA00 ADAPTER ASSY., FUEL CAP
38 74482STKA10 COVER, FUEL ADAPTER
39 74490STKA00 GROMMET, FUEL CAP
40 74494S3MA00 SPRING, FUEL LID OPEN
41 74882S2HA01ZF OPENER ASSY., FUEL NH556L: GRAY
41 74882S2HA01ZG OPENER ASSY., FUEL NH690L: PREMIUM BLACK
42 75450SAA013 OUTLET ASSY., RR. AIR (L. SIDE)
43 75450SNAA01 OUTLET ASSY., RR. AIR (R. SIDE) (SUPERCEDED)
43 75450TR0A00 OUTLET ASSY., RR. AIR
44 85511SB2003YR KNOB ASSY., FUEL OPENER NH556L: GRAY
44 85511SB2003YY KNOB ASSY., FUEL OPENER NH690L: PREMIUM BLACK
45 90103SM4010 BOLT, FLANGE (6X18)
46 90108S0A003 BOLT, FLANGE (6X15)
47 91558SE3003 CLIP, HOOD WIRE
48 91902SB2003 CUSHION, WIRE HARNESS (50X100)
49 93913153G0 SCREW, TAPPING (5X14)
50 957010601608 BOLT, FLANGE (6X16)
51 63324STKA00ZZ GUTTER, R. RR. PILLAR (LOWER)
52 63724STKA00ZZ GUTTER, L. RR. PILLAR (LOWER)
53 66100STK315ZZ PANEL, RR.
54 63220STK305ZZ REINFORCEMENT SET, R. SIDE SILL
55 63620STK305ZZ REINFORCEMENT SET, L. SIDE SILL
