05 EXHAUST PIPE - MUFFLER
1 18160RWCA10 CONVERTER
2 18176P08003 BOLT, CONVERTER
3 18181RWCA00 COVER (LOWER)
4 18182RWCA00 COVER (UPPER)
5 18215SMGE11 RUBBER, EX. MOUNTING (YAMASHITA)
6 18215STKA01 RUBBER, EX. MOUNTING
7 18220SZPA01 PIPE B, EX.
8 18229SLJ033 GASKET, EX. FLEXIBLE
9 18229S5DA01 GASKET, EX. FLEXIBLE
10 18230SA0930 SPRING, FLEXIBLE JOINT
11 18230SV4000 SPRING, FLEXIBLE JOINT
12 18231SNAA00 BOLT B, FLEXIBLE JOINT
16 18393SS0J30 GASKET, PRE CHAMBER (57.5MM-58.5MM)
17 74601STKA00 PLATE A, FLOOR HEAT BAFFLE
18 74602STKA00 PLATE B, FLOOR HEAT BAFFLE
19 74603STKA00 PLATE C, FLOOR HEAT BAFFLE
20 90023PK1000 BOLT, FLANGE (6X10) (IWATA BOLT)
20 90023PR7A01 BOLT, FLANGE (6X12) (IWATA BOLT)
21 90212SA5003 NUT, SELF-LOCK (10MM)
22 934050601604 BOLT-WASHER (6X16)
24 18215STKA11 RUBBER, EX. MOUNTING
25 934050601604 BOLT-WASHER (6X16)
26 957010801608 BOLT, FLANGE (8X16)
27 18307STKA21 MUFFLER, EX.
