05 AT SECONDARY SHAFT - CLUTCH (LOW 2ND-5TH)
1 22500RT4003 CLUTCH ASSY., LOW
2 22600RT4013 CLUTCH ASSY., SECOND & FIFTH
3 22817RT4003 SEAL, RING (30MM)
4 23230RT4000 SHAFT, SECONDARY
5 23411RT4000 GEAR, SECONDARY SHAFT LOW
6 23431RT4010 GEAR, SECONDARY SHAFT SECOND
7 23481RT4010 GEAR, SECONDARY SHAFT FIFTH
8 23495RT4000 GEAR, SECONDARY SHAFT IDLE
9 90012RT4000 BOLT, SPECIAL (16X25) (R)
10 90404RT4000 WASHER, THRUST (37X49X3.4)
11 90405RV2A00 WASHER, THRUST (37X52X2)
12 90440RT4000 COLLAR A (32.89MM)
12 90441RT4000 COLLAR B (32.94MM)
12 90442RT4000 COLLAR C (32.99MM)
12 90443RT4000 COLLAR D (33.04MM)
12 90444RT4000 COLLAR E (33.09MM)
12 90445RT4000 COLLAR F (33.14MM)
12 90446RT4000 COLLAR G (33.19MM)
12 90447RT4000 COLLAR H (33.24MM)
13 90449RT4000 COLLAR (37X45X33)
14 90621RDK000 RING, SNAP (32MM)
15 91005RT4005 BEARING, BALL (25X89X13.5)
16 91020RT4003 BEARING, NEEDLE (32X38X34)
17 91022RT4003 BEARING, NEEDLE (38X44X22.5)
18 91024RT4005 BEARING, NEEDLE (45X50X25)
19 91031RT4003 BEARING, THRUST NEEDLE (37X50X2.5)
20 91032RT4003 BEARING, THRUST NEEDLE (38X54X3.5)
21 91033RT4003 BEARING, THRUST NEEDLE (39X57X2.5)
22 91034RT4003 BEARING, THRUST NEEDLE (38X64X3.5)
23 91037RT4005 BEARING, THRUST NEEDLE (49X66X3)
24 91039RWE007 NEEDLE, THRUST (46X62.95X4.62)(TIMKEN)
25 91302PWR003 O-RING (30.6X1.9) (NOK)
