04 FLOOR - INNER PANEL
1 04655STKA00ZZ PANEL SET, RR. FLOOR
2 64120STKA00ZZ PILLAR, R. FR. (UPPER) (INNER)
3 64130STKA00ZZ PILLAR, R. FR. (LOWER) (INNER)
4 64220STKA00ZZ PILLAR, R. CENTER (INNER)
5 64300STK315ZZ PANEL, R. RR. INSIDE
6 64320STKA00ZZ EXTENSION, R. RR. WHEEL ARCH
7 64324STKA01 SEPARATOR, RR. WHEEL ARCH
8 64330STKA00ZZ WHEELHOUSE, R. RR.
9 64340STKA01ZZ PILLAR, R. RR. (INNER)
10 64520STKA00ZZ PILLAR, L. FR. (UPPER) (INNER)
11 64530STKA00ZZ PILLAR, L. FR. (LOWER) (INNER)
12 64620STKA00ZZ PILLAR, L. CENTER (INNER)
13 64700STK325ZZ PANEL, L. RR. INSIDE
14 64720STKA00ZZ EXTENSION, L. RR. WHEEL ARCH
15 64730STKA00ZZ WHEELHOUSE, L. RR.
16 64740STKA02ZZ PILLAR, L. RR. (INNER)
17 65100STKA10ZZ FLOOR, FR.
18 65140STKA00ZZ SILL, R. FR. INSIDE
19 65190STKA00ZZ SILL, L. FR. INSIDE
20 65522STKA00ZZ EXTENSION, R. FLOOR PANEL
21 65530STKA00ZZ CROSSMEMBER, RR. FLOOR (UPPER)
22 65572STKA00ZZ EXTENSION, L. FLOOR PANEL
23 65610STKA00ZZ FRAME, R. RR.
24 65612STKA00ZZ CAP, R. RR. FRAME
25 65613STKA00ZZ GUSSET, R. RR. PANEL
26 65615STKA00ZZ EXTENSION, R. RR. PANEL (B)
27 65617STKA00ZZ BRACKET, R. RR. SUB-FRAME STAY
28 65618STKA00ZZ STIFFENER, TRAILER HITCH
29 65619STKA00ZZ BRACKET, R. BUMPER BEAM
30 65627STKA00ZZ ROD, RR. MUFFLER MOUNTING
31 65660STKA00ZZ FRAME, L. RR.
32 65662STKA00ZZ CAP, L. RR. FRAME
33 65663STKA00ZZ GUSSET, L. RR. PANEL
34 65665STKA00ZZ EXTENSION, L. RR. PANEL (B)
35 65667STKA00ZZ BRACKET, L. RR. SUB-FRAME STAY
36 65669STKA00ZZ BRACKET, L. BUMPER BEAM
37 65700STKA00ZZ CROSSMEMBER, MIDDLE FLOOR
38 65750STKA00ZZ CROSSMEMBER, RR. FLOOR
39 74611STKA00ZZ GUSSET, RR. WHEELHOUSE
40 90101STK000 BOLT, FLANGE (10X20)
41 90108S0A003 BOLT, FLANGE (6X15)
42 90222SB4000 NUT-WASHER (6MM)
43 934040801608 BOLT-WASHER (8X16)
44 934050601608 BOLT-WASHER (6X16)
45 934051002008 BOLT-WASHER (10X20)
46 934060801608 BOLT-WASHER (8X16)
47 934070802508 BOLT-WASHER (8X25)
48 9405008080 NUT, FLANGE (8MM)
49 64345STKA00ZZ STIFFENER, R. RR. PILLAR (LOWER)
50 64745STKA00ZZ STIFFENER, L. RR. PILLAR (LOWER)
