03 FRONT BULKHEAD - DASHBOARD
1 04601STKA00ZZ STAY SET, R. BULKHEAD SIDE
2 04602STKA01ZZ FRAME SET, FR. BULKHEAD CENTER(UPPER)
3 04603STKA01ZZ CROSSMEMBER SET, FR. BULKHEAD (LOWER)
4 04606STKA00ZZ BRACKET SET, R. FR. SUB-FRAME SUPPORT
5 04608STKA00ZZ MEMBER SET, R. FR. EXTENSION (LOWER)
6 04609STKA00ZZ MEMBER SET, L. FR. EXTENSION (LOWER)
7 04611STKA00ZZ STAY SET, L. FR. BULKHEAD SIDE
8 04616STKA00ZZ BRACKET SET, L. FR. SUB-FRAME SUPPORT
9 04642STKA00ZZ WHEELHOUSE SUB-SET, R. FR.
10 04652STKA00ZZ WHEELHOUSE SUB-SET, L. FR.
11 04674STKA00ZZ BRACKET, R. FR. HOOD CUSHION
12 04677STKA00ZZ BRACKET SET, R. HOOD STOPPER MOUNT
13 04684STKA00ZZ BRACKET, L. FR. HOOD CUSHION
14 04687STKA00ZZ BRACKET SET, L. HOOD STOPPER MOUNT
15 60400STKA01ZZ BULKHEAD, FR.
16 60613STKA00ZZ EXTENSION, R. FR. SHOCK ABSORBER
17 60614STKA00ZZ MEMBER, R. FR. WHEELHOUSE (UPPER)
18 60615STKA00ZZ BULKHEAD, R. FR. SHOCK ABSORBER EXTENSION (FR)
19 60630STKA00ZZ BASE, BATTERY
20 60650STKA00ZZ HOUSING, R. FR. SHOCK ABSORBER
21 60713STKA00ZZ EXTENSION, L. FR. SHOCK ABSORBER
22 60714STKA00ZZ MEMBER, L. FR. WHEELHOUSE (UPPER)
23 60715STKA00ZZ BULKHEAD, L. FR. SHOCK ABSORBER EXTENSION (FR)
24 60750STKA01ZZ HOUSING, L. FR. SHOCK ABSORBER
25 60810STKA01ZZ FRAME, R. FR. SIDE
26 60819STKA00ZZ BRACKET, R. FR. BUMPER BEAM EXTENSION
27 60910STKA01ZZ FRAME, L. FR. SIDE
28 60919STKA00ZZ BRACKET, L. FR. BUMPER BEAM EXTENSION
29 61100STKA00ZZ DASHBOARD (UPPER)
30 61117STKA00ZZ BRACKET, FR. FENDER (RR)
31 61121STKA00ZZ MEMBER, R. DASHBOARD (UPPER)
32 61122STKA00ZZ EXTENSION, R. DASHBOARD MEMBER(UPPER)
33 61126STKA00ZZ MEMBER, L. DASHBOARD (UPPER)
34 61127STKA00ZZ EXTENSION, L. DASHBOARD MEMBER(UPPER)
35 61147STKA00 STAY, L. WINDSHIELD (LOWER)
36 61500STKA00ZZ DASHBOARD (LOWER)
37 74116STKA00 STAY, R. FR. SUB-FRAME (RR)
38 74166STKA00 STAY, L. FR. SUB-FRAME (RR)
39 74250SNAA00 COVER, VIN PLATE
40 90105SV1000 BOLT-WASHER (8X20)
41 90108S0A003 BOLT, FLANGE (6X15)
42 90671SHJA02 RIVET, VIN PLATE (TO ORDER SEE HONDA PIB#A10- 0018/ACURA PIB#B10-0011)
43 934010601208 BOLT-WASHER (6X12)
44 934050601608 BOLT-WASHER (6X16)
45 60759STKA00ZZ STIFFENER, L. FR. FENDER
