02 REAR BRAKE
1 01473SZ3A00 CALIPER SET, RR.
3 42200SZP951 BEARING ASSY., RR. HUB UNIT (MSDS)
4 42510STKA10 DISK, RR. BRAKE DRUM IN
5 42511SP0000 CAP, MAINTENANCE HOLE
6 43018SXS000 CALIPER SUB-ASSY., R. RR. (MSDS)
7 43019SXS000 CALIPER SUB-ASSY., L. RR. (MSDS)
9 43215S9A003 PISTON
10 43227S9AE01 SPRING, PAD
11 43235S84A51 PIN A
12 43244SG0003 RETAINER
13 43244S9A003 RETAINER A
14 43262S84A51 PIN B
15 43352SM4951 SCREW, BLEEDER
16 43353SD5003 CAP, BLEEDER SCREW
17 45240SC2003 BOLT, FLANGE (8X22)
18 90103SJK000 BOLT, CALIPER MOUNTING
19 90113S84901 BOLT, WHEEL (ROCKNEL FASTENER)
19 90113SD4902 BOLT, WHEEL (SAGA)
19 90113SJK901 BOLT, WHEEL (THAI MEIRA)
20 90160SJK000 BOLT-WASHER (12X46)
21 93600060140H SCREW, FLAT (6X14)
22 06435S84J00 SHIM SET, RR.
23 42332SZPA01 SHAFT, RR. AXLE
24 43022SXS000 PAD SET, RR. (MSDS)
25 90305SD4003 NUT, SPINDLE (24MM)
26 91352SFE008 O-RING (75X1.9)
