01 AT TORQUE CONVERTER CASE
1 21101PRP000 PLATE, BEARING SETTING
2 21110RWE305 CASE, TORQUE CONVERTER
4 21221RWE000 PLATE, THIRD BAFFLE
5 22747PW4000 PIPE (57.5MM)
6 22770RDK000 PIPE, JOINT
7 23225RDK000 PLATE, OIL GUIDE
8 23235RDK000 PLATE, OIL GUIDE
9 23237RDK010 COLLAR, OIL GUIDE
10 25313RDK000 PIPE (10X123)
11 25422PN6801 MAGNET, TRANSMISSION
12 90024P1V000 BOLT, SEALING (10MM)
13 90024612000 BOLT, SEALING (8MM)
14 90081PX4003 BOLT, PLUG (18MM)
15 90433639000 WASHER, LOCK (6MM)
16 90471PW7A00 GASKET (10MM)
17 90471PX4000 WASHER, DRAIN PLUG (18MM)
18 90471580000 GASKET (8MM)
19 90701RJB000 PIN, DOWEL (14X25)
20 90705PF4000 PIN, DOWEL (14X20)
21 91001R97003 BEARING, BALL (41X70X9.7/8.5)
22 91006RDK004 BEARING, BALL (28X52X12/8)
23 91010RJF005 BEARING, BALL (12X24X6)
24 91101RDK003 BEARING, NEEDLE (32X63X19)
25 91102RJFT01 BEARING, NEEDLE (40.5X74X24)
26 91104RDK003 BEARING, NEEDLE (29X39X9.5)
28 91206P0Z005 OIL SEAL (35X54X8) (NOK)
29 91207PY4004 OIL SEAL (46X70X8) (ARAI)
30 91306RDK003 O-RING (36.5X2.0)
31 92101060200A BOLT, HEX. (6X20)
32 9430114200 PIN, DOWEL (14X20)
33 957010601208 BOLT, FLANGE (6X12)
34 957010605508 BOLT, FLANGE (6X55)
35 21131PVL000 CAP, TORQUE CONVERTER CASE
36 21216PVL000 PLATE, OIL CATCH
37 21217RDR000 PLATE, BAFFLE
38 91303PVL004 O-RING (60X2.2)
39 957011003508 BOLT, FLANGE (10X35)
