Электропроводка двигателя
1 32110RWCA50 WIRE HARNESS, ENGINE
2 32111RWCA50 SUB-WIRE, STARTER
3 32115P64003 HOLDER, CORRUGATED (10MM) (DARK BLUE)
4 32117P65003 HOLDER, CORRUGATED (15MM) (DARK BLUE)
5 32117RAA003 HOLDER, CORRUGATED (15MM) (DARK BLUE)
6 32118PLC003 HOLDER, CORRUGATED TUBE (19MM)(DARK GREEN)
7 32118P72003 HOLDER, CORRUGATED (19MM) (DARK GREEN)
8 32121RWCA50 HOLDER, ENGINE HARNESS PLUG HOLE COIL
9 32123RAAA00 HOLDER C, ENGINE HARNESS
10 32124RWCA50 HOLDER D, ENGINE HARNESS
11 32125RWCA50 HOLDER E, ENGINE HARNESS
12 32126RWCA50 HOLDER, ENGINE HARNESS MAIN
13 32127RWCA50 COVER, ENGINE HARNESS MAIN
14 32128RTA003 COVER, ENGINE CONTROL MODULE CONNECTOR (A,B)
15 32128RWCA50 HOLDER, ENGINE HARNESS TRANSMISSION
16 32129RTA003 COVER, ENGINE CONTROL MODULE CONNECTOR (C)
17 32129RWCA50 COVER, ENGINE HARNESS TRANSMISSION
18 32130RWCA50 HOLDER, ENGINE HARNESS IN. MANIFOLD
19 32131RWCA50 COVER, ENGINE HARNESS IN. MANIFOLD
20 32134SM4003 BAND, HARNESS OFFSET (10) (122.5MM) (BROWN)
21 32418PNN300 COVER, BATTERY TERMINAL
22 32601SK7900 BOLT, BATTERY TERMINAL
23 32602SK7900 NUT, BATTERY TERMINAL
24 91506RTA003 CLIP A, HARNESS BAND (129.4MM)(DARK VIOLET)
25 91507RTA003 CLIP B, HARNESS BAND (129.4MM)(DARK GREEN)
26 91507SL9003 Хомут (110MM) (7MM HOLE)
27 91508RTA003 CLIP C, HARNESS BAND (179.4MM)(BLACK)
28 91510RAAA01 E-CLIP, HARNESS BAND (179.4MM)(DARK GRAY)
29 91551PNA003 BAND, WIRE HARNESS (172MM) (BLACK)
30 91556PDFE01 BAND, CLAMP (143.2MM) (NATURAL)
31 91558SM4003 CLIP, TUBE (135MM) (BLACK)
32 91558ST5003 CLIP, HARNESS BAND (135MM) (7MM HOLE) (NATURAL)
33 957010601608 Болт (6X16)
    41.1 KB · Просмотры: 232
