Электропроводка двигателя
1 30531RCAA00 SUB-WIRE, KNOCK SENSOR
1 30531RCAA01 SUB-WIRE, KNOCK SENSOR
2 31125RDJA00 CABLE, ALTERNATOR
3 32110RDJA50 WIRE HARNESS, ENGINE
4 32115P64003 HOLDER, CORRUGATED (10MM) (DARK BLUE)
5 32118P72003 HOLDER, CORRUGATED (19MM) (DARK GREEN)
6 32119P2EA01 HOLDER, CORRUGATED (22MM) (DARK BLUE)
7 32129RDJA01 HOLDER C, HARNESS
8 32130RCAA00 HOLDER D, HARNESS
9 32131RDJA00 HOLDER ASSY. E, HARNESS
10 32132RCAA00 HOLDER F, WIRE HARNESS
11 32132RDJA01 HOLDER, CORRUGATED (10MM) (DARK BLUE)
12 32133RDJA00 HOLDER G, HARNESS
13 32610S3VA01 CABLE, SUB-GROUND
14 90149SE0003 BOLT, GROUND (6X16)
15 91506P01003 CLIP A, HARNESS BAND (129.4MM)(DARK GRAY)
16 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
17 91507SL9003 Хомут (110MM) (7MM HOLE)
18 91558P8CA01 CLIP, HARNESS BAND (150MM) (VIOLET)
19 957010601208 Болт 6X12
20 957010601608 Болт (6X16)
21 90114SM4900 BOLT (6X15)
    40.1 KB · Просмотры: 244
