Третий вал
Третий вал
1 22816P6H003 RING, SEAL (35MM)
2 23240RWE000 SHAFT, THIRD
3 23451RYF000 GEAR, THIRDSHAFT THIRD
4 23475RWE000 GEAR, THIRDSHAFT FOURTH
5 90430RDK000 COTTER (19.8MM)
6 90432RDK000 RETAINER, COTTER
7 90554RDK000 WASHER I (53MM) (4.155)
7 90548RDK000 WASHER C (53MM) (4.035)
7 90555RDK000 WASHER J (53MM) (4.175)
7 90549RDK000 WASHER D (53MM) (4.055)
7 90556RDK000 WASHER K (53MM) (4.195)
7 90550RDK000 WASHER E (53MM) (4.075)
7 90557RDK000 WASHER L (53MM) (4.215)
7 90551RDK000 WASHER F (53MM) (4.095)
7 90558RDK000 WASHER M (53MM) (4.235)
7 90552RDK000 WASHER G (53MM) (4.115)
7 90546RDK000 WASHER A (53MM) (3.995)
7 90559RDK000 WASHER N (53MM) (4.255)
7 90553RDK000 WASHER H (53MM) (4.135)
7 90547RDK000 WASHER B (53MM) (4.015)
8 90564RDK000 WASHER A (26.5MM) (1.05)
8 90577RDK000 WASHER N (26.5MM) (2.09)
8 90571RDK000 WASHER H (26.5MM) (1.61)
8 90565RDK000 WASHER B (26.5MM) (1.13)
8 90572RDK000 WASHER I (26.5MM) (1.69)
8 90566RDK000 WASHER C (26.5MM) (1.21)
8 90573RDK000 WASHER J (26.5MM) (1.77)
8 90567RDK000 WASHER D (26.5MM) (1.29)
8 90574RDK000 WASHER K (26.5MM) (1.85)
8 90568RDK000 WASHER E (26.5MM) (1.37)
8 90575RDK000 WASHER L (26.5MM) (1.93)
8 90569RDK000 WASHER F (26.5MM) (1.45)
8 90576RDK000 WASHER M (26.5MM) (2.01)
8 90570RDK000 WASHER G (26.5MM) (1.53)
9 90601RDK000 CIRCLIP, OUTER (24MM)
10 91019RDK013 BEARING, NEEDLE (30X36X32)
11 91034RDK003 NEEDLE, THRUST (30X52X3)
12 91326P4V004 O-RING (26.7X1.9)
    13.9 KB · Просмотры: 209
