AcuraINFO
- 21 Янв 2016
- Гродно
- Дмитрий
- Аcura
Тормозные линии (VSA) (2WD)
1 01464-TZ3-A00 Set,FRBrake Hose 1
2 01465-TZ3-A00 Set,FRBrake Hose 1
3 01466-TZ3-A00 SET,RR BRAKE HOSE 1
4 01468-TZ3-A00 SET,RR BRAKE HOSE 1
5 46330-TZ3-A01 Pipe C Comp,Brake 1
6 46340-TZ3-A01 Pipe D Comp,Brake 1
7 46374-TZ3-A01 Pipe U Comp,Brake 1
8 46375-TZ3-A01 PIPE V COMP,BRAKE 1
9 46376-TZ3-A01 Pipe W Comp,Brake 1
10 46377-TZ3-A01 Pipe X Comp,Brake 1
11 46380-SB0-000 Grommet A, Brake Pipe (Black) 2
11 46380-SH3-000 Grommet A, Brake Pipe 2
12 46391-S5A-Z01 Clip, Brake Pipe 3
13 46391-SJA-003 Clip, Brake Pipe 1
14 46391-TF0-951 Clip, Brake Pipe 8
15 46391-TZ5-A01 Clip,Brake Pipe 1
16 46392-SAA-901 Clip, Brake Pipe 1
17 46393-STX-A51 Clip,Brake Pipe 1
18 46394-SEA-023 Clip D, Brake Pipe 1
19 46395-T2F-A01 Clip, Brake Pipe 2
20 46395-TZ5-A01 Clip,Brake Pipe 1
21 46428-T2A-A00 Bracket, R. FR. 1
22 46429-T2A-A00 Bracket, L. FR. 1
23 46435-T2A-A00 BRACKET A, R. RR. 1
24 46436-T2A-A00 BRACKET A, L. RR. 1
25 46438-TZ3-A00 BRKT B,RR BRAKE H 1
26 46439-TZ3-A00 BRKT B,RR BRAKE H 1
27 46462-SE0-000 Bolt, Oil 4
28 46472-568-000 Gasket, Oil Bolt 8
29 90651-538-000 Clip, Brake Hose 4
29 90651-SV1-A01 Clip, Brake Hose 4
30 95701-08012-08 Bolt, Flange (8X12) 2
31 95701-08016-08 Bolt, Flange (8X16) 6
