Сцепление (4TH-5TH)
Сцепление (4TH-5TH)
1 22533RDK003 SEAT, RETURN SPRING
2 22537PVL003 SPRING, CLUTCH DISK
3 22577RJBE01 PLATE, CLUTCH END (7) (2.7MM)
3 22574RJBE01 PLATE, CLUTCH END (4) (2.4MM)
3 22571RJBE01 PLATE, CLUTCH END (1) (2.1MM)
3 22578RJBE01 PLATE, CLUTCH END (8) (2.8MM)
3 22575RJBE01 PLATE, CLUTCH END (5) (2.5MM)
3 22572RJBE01 PLATE, CLUTCH END (2) (2.2MM)
3 22579RJBE01 PLATE, CLUTCH END (9) (2.9MM)
3 22576RJBE01 PLATE, CLUTCH END (6) (2.6MM)
3 22573RJBE01 PLATE, CLUTCH END (3) (2.3MM)
4 22574RJB003 PLATE, CLUTCH END (4) (2.4MM)
4 22571RJB003 PLATE, CLUTCH END (1) (2.1MM)
4 22578RJB003 PLATE, CLUTCH END (8) (2.8MM)
4 22575RJB003 PLATE, CLUTCH END (5) (2.5MM)
4 22572RJB003 PLATE, CLUTCH END (2) (2.2MM)
4 22579RJB003 PLATE, CLUTCH END (9) (2.9MM)
4 22576RJB003 PLATE, CLUTCH END (6) (2.6MM)
4 22573RJB003 PLATE, CLUTCH END (3) (2.3MM)
4 22577RJB003 PLATE, CLUTCH END (7) (2.7MM)
5 22642RDK003 SPRING, CLUTCH RETURN
6 22642RJBA01 SPRING, CLUTCH RETURN
7 22645RWE003 DISK, CLUTCH
8 22646RWE003 DISK, CLUTCH
9 22654RJB003 SEAT, RETURN SPRING
10 22657RJBE01 PLATE, CLUTCH (1.6MM)
11 22657RJB013 PLATE, CLUTCH (1.6MM)
12 22659PVL003 PLATE, CLUTCH WAVE (1.6MM)
13 22659RWE003 PLATE, CLUTCH WAVE (1.6MM)
14 22661RWE003 GUIDE, CLUTCH (4-5)
15 22690RWE003 PISTON, CLUTCH
16 22680RWE003 PISTON, CLUTCH
17 90603P0Z000 CIRCLIP, OUTER (44MM)
18 90605P0Z000 RING, SNAP (141MM)
19 91302P0Z003 O-RING (44.1X2.2) (NOK)
20 91303PY4004 O-RING (119.1X2.3) (NOK)
    36.7 KB · Просмотры: 222
