Сцепление (4TH-5TH)
Сцепление (4TH-5TH)
1 22533RDK003 SEAT, RETURN SPRING
2 22537PVL003 SPRING, CLUTCH DISK
3 22577RYF003 PLATE, CLUTCH END (7) (2.7MM)
3 22571RYF003 PLATE, CLUTCH END (1) (2.1MM)
3 22578RYF003 PLATE, CLUTCH END (8) (2.8MM)
3 22572RYF003 PLATE, CLUTCH END (2) (2.2MM)
3 22579RYF003 PLATE, CLUTCH END (9) (2.9MM)
3 22573RYF003 PLATE, CLUTCH END (3) (2.3MM)
3 22574RYF003 PLATE, CLUTCH END (4) (2.4MM)
3 22575RYF003 PLATE, CLUTCH END (5) (2.5MM)
3 22576RYF003 PLATE, CLUTCH END (6) (2.6MM)
4 22642RDK003 SPRING, CLUTCH RETURN
5 22642RYF003 SPRING, CLUTCH RETURN
6 22645RYF003 DISK, CLUTCH
7 22654RJB003 SEAT, RETURN SPRING
8 22657RYF003 PLATE, CLUTCH (1.6MM)
9 22659RYF003 PLATE, CLUTCH WAVE (1.6MM)
10 22661RYF003 GUIDE, FOURTH & FIFTH CLUTCH
11 22680RWE003 PISTON, CLUTCH
12 22690RYF003 PISTON, CLUTCH
13 90603P0Z000 CIRCLIP, OUTER (44MM)
14 90605P0Z000 RING, SNAP (141MM)
15 91302P0Z003 O-RING (44.1X2.2) (NOK)
16 91303PGH003 O-RING (121.3X2.3) (F.C.C.)
17 91303PY4004 O-RING (119.1X2.3) (NOK)
    36.8 KB · Просмотры: 182
