Стояночный тормоз
Стояночный тормоз
1 47101STXA02 PEDAL SET, FOOT PARKING BRAKE
2 47120S6AN01 PAD, PEDAL
3 47159S6AN01 NUT, PUSH
4 47210STXA02 WIRE A, PARKING BRAKE
5 47215STXA01 BRACKET T, BRAKE WIRE
6 47220STXA03ZB CABLE ASSY., RELEASE *NH556L*(GRAY)
6 47220STXA03ZA CABLE ASSY., RELEASE *NH167L*(GRAPHITE BLACK)
6 47220STXA03ZD CABLE ASSY., RELEASE *YR351L*(BURGUNDY BROWN)
6 47220STXA03ZC CABLE ASSY., RELEASE *YR240L*(LIGHT CREAM IVORY)
7 47342STXA01 SWITCH, PARKING BRAKE
8 47410S6AN01 SHOCK ABSORBER
9 47520STXA02 WIRE B, R. PARKING BRAKE
9 47520STXA01 WIRE B, R. PARKING BRAKE
10 47538S2R000 NUT, ADJUSTER
11 47560STXA02 WIRE B, L. PARKING BRAKE
12 47572S3VA00 BASE, WIRE GUIDE
13 47574S0X000 SPRING, RETURN
14 90361SV4003 NUT, PAINT CUTTING (6MM)
15 90651SV1A01 CLIP, BRAKE HOSE
16 934030802008 BOLT-WASHER (8X20)
17 934030601608 BOLT-WASHER (6X16)
18 934010801608 BOLT-WASHER (8X16)
18 934030801608 BOLT-WASHER (8X16)
19 934030802008 BOLT-WASHER (8X20)
20 934030802508 BOLT-WASHER (8X25)
21 938940501607 SCREW-WASHER (5X16)
22 9390334210 SCREW, TAPPING (4X10)
23 94001080000S NUT, HEX. (8MM)
24 9405008080 Гайка (8mm)
25 957010601608 Болт (6X16)
26 957010802008 Болт
    27 KB · Просмотры: 225
