Стартер (DENSO)
Стартер (DENSO)
1 30202RYE003 COLLAR, CLUTCH STOP
2 31200RYEA71 STARTER MOTOR ASSY. (DUDV3) (DENSO)
2 31200RYEA71RM STARTER, CORE ID (428000-6780)(9742809-678) (RMD) (DENSO)
3 31202RYEA71 END FRAME, COMMUTATOR
4 31203RYEA01 LEVER, PINION DRIVE
5 31296R70A51 TERMINAL SET
6 31205RYEA01 YOKE (N/A FOR USA: SEE ASSEMBLY)
7 31206RK2A01 ARMATURE
8 31207RYEA01 CLUTCH, OVERRUNNING
9 31208RYEA01 SCREW, PAN (4MM)
10 31213RK2A01 SHAFT, DRIVE
11 31214RK2A01 GEAR (INNER)
12 31215RK2A01 GEAR, PLANETARY
13 31216RYEA01 SHOCK ABSORBER
14 31217RYEA01 PLATE, SEAL
15 31218RYEA01 WASHER A
16 31219RYEA01 WASHER B
17 31220PH9004 NUT, HEX. (8MM)
18 31223RYEA01 NUT
19 31224RYEA01 INSULATOR
20 31225RYEA01 PLATE, BRUSH HOLDER
21 31226RYEA01 BOLT, THROUGH
22 31227RYEA01 COVER
23 31228RYEA01 RING, SNAP
24 31270RJAA01 GASKET, STARTER MOTOR
27 31295RYEA71 SHAFT SET, IDLE
28 9451018000 CIRCLIP, OUTER (18MM)
29 31218RK2A01 WASHER A
30 31231RYEA01 SEAL, LEVER
    36.5 KB · Просмотры: 202
