Рычаг переключения передач
1 35505692003 Лампочка (14V 1,4W)
2 39550S01A01 SOLENOID ASSY., AT SHIFT LOCK (PONTIAC)
3 54020S3VA81 BRACKET, BASE
4 54030S3VA81 RELEASE, SHIFT LOCK
5 54031S30981 SPRING, RELEASE RETURN
6 54032S30981 CUSHION, SHIFT LOCK STOPPER
7 54033S30981 STOPPER, SHIFT LOCK
8 54034S30981 STOPPER, REVERSE LOCK
9 54111S30981 PLUNGER, DETENT
10 54112S30981 SPRING, DETENT
11 54130S3V305ZA KNOB, SELECT *NH1L*(BLACK)
12 54200S3VA82 BRACKET, DETENT
13 54206S30981 COLLAR, BRACKET
14 54221S3VA81 RING, SELECT KNOB
15 54315S3VA81 WIRE, CONTROL
16 54710S3VA82ZA ESCUTCHEON, CONSOLE *NH286L*(CHAMOIS GRAY NO. 3)
17 54714S3VA81ZA LID, ESCUTCHEON *TCHROME*(CHROMIUM PLATING)
18 54716S3VA82 GARNISH ASSY., ESCUTCHEON
19 54718S3VA82 PLATE, BACK-UP
20 54719S3VA82 PLATE, ESCUTCHEON
21 74610S3VA00 BRACKET, AT SHIFTER
22 90351SB2003 NUT, FLANGE (8MM)
23 91641SM4003 GROMMET, SCREW (4MM)
24 934010601608 BOLT-WASHER (6X16)
25 934030602008 BOLT-WASHER (6X20)
26 934050802004 BOLT-WASHER (8X20)
27 957010602008 BOLT, FLANGE (6X20)
28 934050803008 BOLT-WASHER (8X30)
    40 KB · Просмотры: 210
