Промежуточный вал ('01-'02)
1 21215P0Z000 HOLDER, IDLE SHAFT
2 23220PGH010 COUNTERSHAFT
3 23421P7W000 GEAR, COUNTERSHAFT LOW
4 23427PGH000 GEAR, PARKING
5 23441RAY000 GEAR, COUNTERSHAFT SECOND
6 23451P7W000 GEAR, COUNTERSHAFT THIRD
6 23451P7W010 GEAR, COUNTERSHAFT THIRD
7 23471PGH000 GEAR, COUNTERSHAFT FOURTH
8 23491PGH000 GEAR, COUNTERSHAFT FIFTH
9 23531P7Z000 GEAR, COUNTERSHAFT REVERSE
10 23541P0Z000 GEAR, REVERSE IDLE
11 23542P7T000 SHAFT, REVERSE IDLE GEAR
12 23565P0Z000 SELECTOR, REVERSE GEAR
13 23566P0Z010 HUB, SELECTOR
14 90203P0Z000 NUT, FLANGE (24MM) (LEFT HAND THREAD)
15 90401P0Z000 WASHER, THRUST (14X30X1)
16 90402P0Z000 WASHER, SPRING (24MM)
17 90408PY4000 WASHER, THRUST (14X30X1)
18 90431P6H000 COTTER (31MM)
19 90441PGH000 COLLAR (35X47X45)
20 90522P7W010 WASHER C (31X63.5X8.6)
20 90523P7W000 WASHER D (31X63.5X8.5)
20 90520P7W000 WASHER A (31X63.5X8.5)
20 90523P7W010 WASHER D (31X63.5X8.6)
20 90520P7W010 WASHER A (31X63.5X8.6)
20 90521P7W000 WASHER B (31X63.5X8.5)
20 90521P7W010 WASHER B (31X63.5X8.6)
20 90522P7W000 WASHER C (31X63.5X8.5)
21 90614P0Z000 RING, SNAP (35MM)
22 91022P0Z013 BEARING, THRUST NEEDLE (42X67X3.5)
23 91024PAX006 BEARING, NEEDLE (40X46X14.5) (TORRINGTON)
24 91025P24006 BEARING, NEEDLE (14X18X15) (TORRINGTON)
25 91028P0Z013 BEARING, NEEDLE (35X41X25.8) (NTN)
26 91035PAX016 BEARING, NEEDLE (42X50X19)
27 91308PW4003 Кольцо уплотнительное
28 957010803208 BOLT, FLANGE (8X32)
29 90445PGH000 COLLAR (35X47X7.8)
    32.6 KB · Просмотры: 178
