Передняя головка блока цилиндров (2)
1 12100R70305 CYLINDER HEAD ASSY., FR.
2 12204PJ7305 GUIDE, VALVE (OVER SIZE)
3 12205PJ7305 GUIDE, EX. VALVE (OVER SIZE)
4 12207634300 WASHER, SEALING BOLT
5 12208P8CA01 BOLT, SEALING (28MM)
6 12210PZ1004 SEAL A, VALVE STEM (NOK)
7 12211PZ1004 SEAL B, VALVE STEM (NOK)
8 12230P8AA00 COVER ASSY., FR. CAMSHAFT THRUST
9 12251RKG004 GASKET, CYLINDER HEAD
10 12432R72A01 BRIDGE, ROCKER SHAFT
11 12433R72A00 HOLDER ASSY., FR. ROCKER SHAFT
12 14820RKG003 MOTION, LOST
13 36533R70A00 STAY, FR. LAF CONNECTOR
14 90004PE2005 BOLT, SEALING (10MM)
15 90005PAAA01 BOLT-WASHER (12X163)
16 90026P8AA00 BOLT, STUD (8X41)
17 90427PFD000 WASHER, SEALING (8MM)
18 90705PT0000 PIN, DOWEL (16X22)
19 91301P8AA00 O-RING (48.5X2.4)
20 92900080251B BOLT, STUD (8X25)
21 92900080321B BOLT, STUD (8X32)
22 9430110120 PIN, DOWEL (10X12)
23 9430208100 PIN B, DOWEL (8X10)
24 957010801208 BOLT, FLANGE (8X12)
25 957010802808 BOLT, FLANGE (8X28)
26 957010804008 BOLT, FLANGE (8X40)
27 957011001608 BOLT, FLANGE (10X16)
28 958010806008 BOLT, FLANGE (8X60)
    35.5 KB · Просмотры: 181
