Передача
Передача
1 21421RJB000 PLATE, BREATHER
2 21431RJB000 GUTTER, OIL
3 29000RWE000 TRANSFER ASSY.
4 29121RJB000 COVER, TRANSFER
5 29200RWE000 GEAR SET, TRANSFER HYPOID
6 29311RJB000 SPACER, PINION
7 29321RJB000 WASHER, THRUST (32.1X37X1)
8 29371RDK000 SHIM K (40MM) (1.02)
8 29365RDK000 SHIM E (40MM) (0.84)
8 29372RDK000 SHIM L (40MM) (1.05)
8 29366RDK000 SHIM F (40MM) (0.87)
8 29373RDK000 SHIM M (40MM) (1.08)
8 29367RDK000 SHIM G (40MM) (0.90)
8 29361RDK000 SHIM A (40MM) (0.72)
8 29374RDK000 SHIM N (40MM) (1.11)
8 29368RDK000 SHIM H (40MM) (0.93)
8 29362RDK000 SHIM B (40MM) (0.75)
8 29375RDK000 SHIM O (40MM) (1.14)
8 29369RDK000 SHIM I (40MM) (0.96)
8 29363RDK000 SHIM C (40MM) (0.78)
8 29370RDK000 SHIM J (40MM) (0.99)
8 29364RDK000 SHIM D (40MM) (0.81)
9 29422P1C000 SHIM (25MM) (2.03)
9 29417P1C000 SHIM (25MM) (1.88)
9 29429P1C000 SHIM (25MM) (2.24)
9 29412P1C000 SHIM (25MM) (1.73)
9 29423P1C000 SHIM (25MM) (2.06)
9 29418P1C000 SHIM (25MM) (1.91)
9 29424P1C000 SHIM (25MM) (2.09)
9 29419P1C000 SHIM (25MM) (1.94)
9 29413P1C000 SHIM (25MM) (1.76)
9 29425P1C000 SHIM (25MM) (2.12)
9 29420P1C000 SHIM (25MM) (1.97)
9 29414P1C000 SHIM (25MM) (1.79)
9 29426P1C000 SHIM (25MM) (2.15)
9 29421P1C000 SHIM (25MM) (2.00)
9 29415P1C000 SHIM (25MM) (1.82)
9 29427P1C000 SHIM (25MM) (2.18)
9 29411P1C000 SHIM (25MM) (1.70)
9 29416P1C000 SHIM (25MM) (1.85)
9 29428P1C000 SHIM (25MM) (2.21)
10 29411RWE010 TUBE, TRANSFER BREATHER
11 29412RWE000 TUBE A, TRANSFER BREATHER
12 29421RDK000 CLAMP, BREATHER TUBE
13 29431RWE000 STAY A, TRANSFER BREATHER
14 29611RWE000 FLANGE, COMPANION
15 41423RDK000 SHIM W (80MM) (2.18)
15 41404RDK000 SHIM D (80MM) (1.61)
15 41436RDK000 SHIM AJ (80MM) (2.57)
15 41417RDK000 SHIM Q (80MM) (2.00)
15 41430RDK000 SHIM AD (80MM) (2.39)
15 41411RDK000 SHIM K (80MM) (1.82)
15 41424RDK000 SHIM X (80MM) (2.21)
15 41405RDK000 SHIM E (80MM) (1.64)
15 41437RDK000 SHIM AK (80MM) (2.60)
15 41418RDK000 SHIM R (80MM) (2.03)
15 41431RDK000 SHIM AE (80MM) (2.42)
15 41412RDK000 SHIM L (80MM) (1.85)
15 41425RDK000 SHIM Y (80MM) (2.24)
15 41406RDK000 SHIM F (80MM) (1.67)
15 41438RDK000 SHIM AL (80MM) (2.63)
15 41419RDK000 SHIM S (80MM) (2.06)
15 41432RDK000 SHIM AF (80MM) (2.45)
15 41413RDK000 SHIM M (80MM) (1.88)
15 41426RDK000 SHIM Z (80MM) (2.27)
15 41407RDK000 SHIM G (80MM) (1.70)
15 41439RDK000 SHIM AM (80MM) (2.66)
15 41420RDK000 SHIM T (80MM) (2.09)
15 41401RDK000 SHIM A (80MM) (1.52)
15 41433RDK000 SHIM AG (80MM) (2.48)
15 41414RDK000 SHIM N (80MM) (1.91)
15 41427RDK000 SHIM AA (80MM) (2.30)
15 41408RDK000 SHIM H (80MM) (1.73)
15 41421RDK000 SHIM U (80MM) (2.12)
15 41402RDK000 SHIM B (80MM) (1.55)
15 41434RDK000 SHIM AH (80MM) (2.51)
15 41415RDK000 SHIM O (80MM) (1.94)
15 41428RDK000 SHIM AB (80MM) (2.33)
15 41409RDK000 SHIM I (80MM) (1.76)
15 41422RDK000 SHIM V (80MM) (2.15)
15 41403RDK000 SHIM C (80MM) (1.58)
15 41435RDK000 SHIM AI (80MM) (2.54)
15 41416RDK000 SHIM P (80MM) (1.97)
15 41429RDK000 SHIM AC (80MM) (2.36)
15 41410RDK000 SHIM J (80MM) (1.79)
16 41932PZP003 CLAMP, BREATHER TUBE (1.0)
17 41935RWE013 BOX, BREATHER TUBE
18 90026PS5000 BOLT, FLANGE (10X105)
19 90081PE9000 BOLT, PLUG (20MM)
20 90203PCY000 NUT, HEX. (27MM)
21 90402PL9000 WASHER, SPRING (27MM)
22 90705PF4000 PIN, DOWEL (14X20)
23 91121PGH003 BEARING, TAPER (25X52X19.25)
24 91121RJB003 BEARING, TAPER (32X65X22.25)
25 91123RDK003 BEARING, TAPER (40X75X24)
26 91124RDK003 BEARING, TAPER (50X80X24)
27 91201RJB003 OIL SEAL (42X67X9) (NOK)
28 91202RDK003 Сальник (48X67X7.5)
29 91301PCY003 O-RING (28X2.6)
30 91302PCY003 RING, BACK-UP (28MM)
31 91303RDK003 O-RING (120.7X2.4) (NOK)
32 9410920000 Шайба уплотнительная сливного/заливного отверстия заднего редуктора, заливного отверстия МКПП (20mm)
33 957010601008 BOLT, FLANGE (6X10)
34 957010601608 Болт (6X16)
35 957010802508 BOLT, FLANGE (8X25)
36 957011005008 BOLT, FLANGE (10X50)
    39.5 KB · Просмотры: 288
