Передача ('01-'02)
1 29000PGH010 TRANSFER ASSY.
2 29102PGH000 SHAFT, TRANSFER
3 29121PGV020 COVER, TRANSFER
4 29210PGH010 GEAR SET, TRANSFER HYPOID
5 29361PH8000 WASHER, SPRING (22MM)
6 29426P1C000 SHIM (25MM) (2.15)
6 29420P1C000 SHIM (25MM) (1.97)
6 29414P1C000 SHIM (25MM) (1.79)
6 29427P1C000 SHIM (25MM) (2.18)
6 29421P1C000 SHIM (25MM) (2.00)
6 29415P1C000 SHIM (25MM) (1.82)
6 29428P1C000 SHIM (25MM) (2.21)
6 29422P1C000 SHIM (25MM) (2.03)
6 29416P1C000 SHIM (25MM) (1.85)
6 29429P1C000 SHIM (25MM) (2.24)
6 29423P1C000 SHIM (25MM) (2.06)
6 29417P1C000 SHIM (25MM) (1.88)
6 29411P1C000 SHIM (25MM) (1.70)
6 29424P1C000 SHIM (25MM) (2.09)
6 29418P1C000 SHIM (25MM) (1.91)
6 29412P1C000 SHIM (25MM) (1.73)
6 29425P1C000 SHIM (25MM) (2.12)
6 29419P1C000 SHIM (25MM) (1.94)
6 29413P1C000 SHIM (25MM) (1.76)
7 40441PGH000 FLANGE, COMPANION
8 41271P6R000 SPACER, PINION
9 41368PS3000 SHIM H (35MM) (0.93)
9 41362PS3000 SHIM B (35MM) (0.75)
9 41369PS3000 SHIM I (35MM) (0.96)
9 41363PS3000 SHIM C (35MM) (0.78)
9 41370PS3000 SHIM J (35MM) (0.99)
9 41364PS3000 SHIM D (35MM) (0.81)
9 41371PS3000 SHIM K (35MM) (1.02)
9 41365PS3000 SHIM E (35MM) (0.84)
9 41372PS3000 SHIM L (35MM) (1.05)
9 41366PS3000 SHIM F (35MM) (0.87)
9 41373PS3000 SHIM M (35MM) (1.08)
9 41367PS3000 SHIM G (35MM) (0.90)
9 41361PS3000 SHIM A (35MM) (0.72)
9 41374PS3000 SHIM N (35MM) (1.11)
10 41407PW8010 SHIM G (75MM) (1.82)
10 41414PGV000 SHIM ZI (75MM) (2.66)
10 41404PW8010 SHIM D (75MM) (1.73)
10 41426PW8010 SHIM Z (75MM) (2.39)
10 41411PGV000 SHIM ZF (75MM) (2.57)
10 41401PGV000 SHIM AA (75MM) (1.52)
10 41420PW8010 SHIM T (75MM) (2.21)
10 41408PGV000 SHIM ZC (75MM) (2.48)
10 41414PW8010 SHIM N (75MM) (2.03)
10 41405PGV000 SHIM AE (75MM) (1.64)
10 41411PW8010 SHIM K (75MM) (1.94)
10 41402PGV000 SHIM AB (75MM) (1.55)
10 41421PW8010 SHIM U (75MM) (2.24)
10 41408PW8010 SHIM H (75MM) (1.85)
10 41415PW8010 SHIM O (75MM) (2.06)
10 41405PW8010 SHIM E (75MM) (1.76)
10 41412PGV000 SHIM ZG (75MM) (2.60)
10 41402PW8010 SHIM B (75MM) (1.67)
10 41422PW8010 SHIM V (75MM) (2.27)
10 41409PGV000 SHIM ZD (75MM) (2.51)
10 41416PW8010 SHIM P (75MM) (2.09)
10 41406PGV000 SHIM ZA (75MM) (2.42)
10 41412PW8010 SHIM L (75MM) (1.97)
10 41403PGV000 SHIM AC (75MM) (1.58)
10 41423PW8010 SHIM W (75MM) (2.30)
10 41409PW8010 SHIM I (75MM) (1.88)
10 41417PW8010 SHIM Q (75MM) (2.12)
10 41406PW8010 SHIM F (75MM) (1.79)
10 41413PGV000 SHIM ZH (75MM) (2.63)
10 41403PW8010 SHIM C (75MM) (1.70)
10 41424PW8010 SHIM X (75MM) (2.33)
10 41410PGV000 SHIM ZE (75MM) (2.54)
10 41418PW8010 SHIM R (75MM) (2.15)
10 41407PGV000 SHIM ZB (75MM) (2.45)
10 41413PW8010 SHIM M (75MM) (2.00)
10 41404PGV000 SHIM AD (75MM) (1.61)
10 41425PW8010 SHIM Y (75MM) (2.36)
10 41410PW8010 SHIM J (75MM) (1.91)
10 41419PW8010 SHIM S (75MM) (2.18)
11 90201PH8000 NUT, HEX. (22MM)
12 90705PF4000 PIN, DOWEL (14X20)
13 91121PGH003 BEARING, TAPER (25X52X19.25)
14 91122PGH003 BEARING, TAPER (45X75X24)
15 91123PGH003 BEARING, TAPER (35X72X28)
16 91123PS5013 BEARING, TAPER (28X58X20)
17 91201PFMF01 OIL SEAL (38X62X9)
18 91303P4T003 O-RING (23X2.6) (NOK)
19 91304PGV003 O-RING (90X2.2)
20 91304P4T003 RING, BACK-UP (23MM)
21 91305PGV003 Сальник
22 957010802508 BOLT, FLANGE (8X25)
23 957011005008 BOLT, FLANGE (10X50)
24 957011010008 BOLT, FLANGE (10X100)
