Основной вал ('01-'02)
1 22814P0X003 RING, SEALING (32MM)
2 22815P4P003 RING, SEALING (29MM)
3 23210PGH000 MAINSHAFT
4 23455P7W000 GEAR, MAINSHAFT THIRD
5 23461PGH000 GEAR, MAINSHAFT FOURTH
6 23481PGH000 GEAR, MAINSHAFT FIFTH
7 90201P0Z000 NUT, FLANGE (24MM)
8 90402P0Z000 WASHER, SPRING (24MM)
9 90419P7W000 WASHER, THRUST (41X73X8.10)
9 90414P7W000 WASHER, THRUST (41X73X7.85)
9 90415P7W000 WASHER, THRUST (41X73X7.90)
9 90416P7W000 WASHER, THRUST (41X73X7.95)
9 90417P7W000 WASHER, THRUST (41X73X8.00)
9 90418P7W000 WASHER, THRUST (41X73X8.05)
10 90423P6H000 WASHER, THRUST (27X47X5)
11 90501P7Z010 COLLAR (27X34X58.5)
12 90603P0X000 SET-RING (23MM)
13 91011P7W003 BEARING, NEEDLE (34X40X20)
14 91017PGH003 BEARING, NEEDLE (23X29X21)
15 91018PW7A02 Подшипник АКПП (34X46X2)
16 91021P0Z013 BEARING, THRUST NEEDLE (60X74X2.5)
17 91023P7Z003 BEARING, THRUST NEEDLE (34X53.5X2.5)
18 91029P7W003 BEARING, NEEDLE (53X59X21.5)
19 91316PR9003 O-RING (33X1.9) (ARAI)
    25.3 KB · Просмотры: 190
