Нижняя задняя ARM
1 42522SLJ003 CLAMP, WIRE (BLACK)
2 42524SNA003 CLIP, CONNECTOR (BLACK)
3 52210STXA02 KNUCKLE, R. RR.
4 52215STXA02 KNUCKLE, L. RR.
5 52300STXA02 SPRING, RR. STABILIZER
6 52306STXA02 BUSH, RR. STABILIZER HOLDER
7 51308SZ3010 BRACKET, STABILIZER
8 52320STXA02 LINK, R. RR. STABILIZER
9 52325STXA02 LINK, L. RR. STABILIZER
11 52345STXA01 ARM A, RR. (LOWER)
12 52350STXA01 ARM B, R. RR. (LOWER)
13 52360STXA01 ARM B, L. RR. (LOWER)
14 52371STXA02 ARM, R. RR. TRAILING
15 52372STXA02 ARM, L. RR. TRAILING
16 52388SHJA01 PLATE, CAM
17 52390STXA01 ARM ASSY., R. RR. (UPPER)
18 52400STXA01 ARM ASSY., L. RR. (UPPER)
19 52454SEPA01 BOOT, RR. DUST (UPPER)
20 57470STXA01 SENSOR ASSY., R. RR.
21 57475STXA01 SENSOR ASSY., L. RR.
22 90002STXA00 NUT, FLANGE (10MM)
23 90100SHJA00 BOLT, FLANGE (6X16.5)
24 90162SR3000 BOLT, FLANGE (14X60)
25 90170STXA01 BOLT (14X81)
26 90173STXA02 BOLT B, ARM ADJUST (LOWER)
27 90215SHJA00 NUT, SELF-LOCK (12MM) (CLINCH)
28 90215SJCA00 NUT, SELF-LOCK (14MM) (CLINCH)
29 90212SA5003 NUT, SELF-LOCK (10MM)
30 90362STXA01 NUT, SELF-LOCK (14MM) (NYLON)
31 90363STXA02 NUT, CASTLE (12MM)
32 90401STXA00 WASHER, ARM (LOWER)
33 90651SWA000 WASHER, RR. KNUCKLE
34 90701SX0003 CLIP, ARM (UPPER)
35 934021002008 BOLT-WASHER (10X20)
