Наружная панель-панель крыши
1 04631S3VA00ZZ PANEL, R. SIDE SILL
1 04631S3V306ZZ PANEL, R. SIDE SILL
2 04635S3V306ZZ PANEL SET, R. FR. (OUTER)
2 04635S3V305ZZ PANEL SET, R. FR. (OUTER)
3 04636S3VA80ZZ PANEL SET, R. RR. (OUTER) (DOT)
3 04636S3VA92ZZ PANEL SET, R. RR. (OUTER) (DOT)
4 04641S3V306ZZ PANEL, L. SIDE SILL
4 04641S3VA00ZZ PANEL, L. SIDE SILL
5 04645S3V306ZZ PANEL SET, L. FR. (OUTER)
5 04645S3V305ZZ PANEL SET, L. FR. (OUTER)
6 04646S3VA80ZZ PANEL SET, L. RR. (OUTER) (DOT)
6 04646S3VA90ZZ PANEL SET, L. RR. (OUTER) (DOT)
7 62100S3V307ZZ PANEL COMP SET ROOF
8 62130S3VA00ZZ RAIL, RR. ROOF
9 63121S3VA00ZZ STIFFENER, R. FR. PILLAR (UPPER)
10 63131S3VA01ZZ STIFFENER, R. FR. PILLAR (LOWER)
11 63210S3VA00ZZ STIFFENER, R. CENTER PILLAR
12 63320S3VA01ZZ GUTTER, R. RR. PILLAR
13 63521S3VA00ZZ STIFFENER, L. FR. PILLAR (UPPER)
14 63531S3VA01ZZ STIFFENER, L. FR. PILLAR (LOWER)
15 63610S3VA00ZZ STIFFENER, L. CENTER PILLAR
16 63720S3VA00ZZ GUTTER, L. RR. PILLAR
17 63750S3VA00ZZ HOLDER, JACK
18 63910S3VA01ZZ LID, FUEL FILLER
20 65756S3VA00ZZ BRACKET, R. RR. BUMPER SIDE
21 65786S3VA00ZZ BRACKET, L. RR. BUMPER SIDE
22 74401S3VA00 INSULATOR, JACK
23 74411S3VA00 CABLE, FUEL LID OPENER
25 74422ST5000 CUSHION, FUEL FILLER LID
26 74423SZ3003 HOLDER, FUEL CAP
27 74882S3VA01 OPENER ASSY., FUEL
28 75450S10000 OUTLET ASSY., RR. AIR
29 85511SB2003ZQ Ручка открывания бензобака
29 85511SB2003YH KNOB ASSY., FUEL OPENER *YR203L*(SADDLE)
31 90106SE3000 BOLT-WASHER (6X12)
32 90108S0A003 Болт (6X15)
33 934030601608 BOLT-WASHER (6X16)
35 9405006080 Гайка (6 MM)
36 74494S3MA00 SPRING, FUEL LID OPEN
37 85280S3VA00 PROTECTION, SIDE PANEL (OUTER)
    31.2 KB · Просмотры: 232
