Механизм
Механизм
1 53010STXA01 JOINT SET, BALL (INNER)
2 53434S87A01 CLIP
3 53436STXA51 RUBBER, MOUNTING
4 53438SZAA00 BRACKET B, POWER STEERING RACK
5 53449S0XA01 CLAMP, BELLOWS
6 53501SHJA00 GROMMET A, STEERING
7 53534S0XA02 BELLOWS
8 53535S0XA01 SPACER
9 53540STXA02 END, R. TIE ROD
10 53546STXA02 BOOT, TIE ROD END
11 53560STXA02 END, L. TIE ROD
12 53601STXA02 RACK ASSY., POWER STEERING
13 53685SHJA02 BUSH, MOUNTING
14 90107STXA50 BOLT, FLANGE (12X51)
15 90301SDBA01 NUT, HEX. (24MM)
16 934021002008 BOLT-WASHER (10X20)
16 934121002008 BOLT-WASHER (10X20)
17 90362SZAA00 NUT, FLANGE (12MM)
18 9420130220 PIN, SPLIT (3.0X22)
19 53536S0XA01 WASHER, TAB
20 53502SHJA00 GROMMET B, STEERING
    9.8 KB · Просмотры: 210
