Масляный насос
Масляный насос
1 14535R70A00 PLATE, TIMING BELT STOPPER
2 15100RYEA11 PUMP ASSY., OIL (YAMADA)
3 15115P8AA01 GASKET, OIL HOLE
4 15150R72A00 JOINT ASSY., OIL PIPE
5 15220RYEA01 STRAINER, OIL
6 15221RYEA01 O-RING
7 15231PE0000 VALVE, RELIEF
8 15232R70A01 SPRING, RELIEF VALVE
9 15233R70A01 BOLT, SEALING (18MM)
10 15400PLMA01 FILTER, OIL (FILTECH TOYO ROKI) (SOLD IN MULTIPLES OF 30)
11 15811RYEA11 VALVE ASSY., SPOOL
12 15825P8AA01 FILTER ASSY., SPOOL VALVE
13 36171RYEA01 SOLENOID ASSY.
14 36172P8AA01 GASKET, SOLENOID BASE
16 37250PR3003 SWITCH ASSY., VALVE TIMING OILPRESSURE
20 90015PH1013 HOLDER, OIL FILTER
21 92900060161B BOLT, STUD (6X16)
22 90051P8AA00 BOLT, FLANGE (6X35) (SEAL)
23 91212R70A02 OIL SEAL (41X56X7) (NOK)
24 91308P8AA01 O-RING (18.3X3.5)
25 91309P8AA01 O-RING (16.3X3.5)
26 91319PR3003 O-RING (13X1.5) (ARAI)
27 92900060181B BOLT, STUD (6X18)
29 9405006080 NUT, FLANGE (6MM)
30 9430106100 PIN, DOWEL (6X10)
32 957010601808 BOLT, FLANGE (6X18)
33 957010602008 BOLT, FLANGE (6X20)
34 957010805008 BOLT, FLANGE (8X50)
35 957010807508 BOLT, FLANGE (8X75)
37 37240R72A01 SWITCH ASSY., OIL PRESSURE (SEE SERVICE BULLETIN #09-012 FOR REPLACING THIS PART)
    35.7 KB · Просмотры: 216
