Левая боковая крышка
1 21240P7W000 COVER, L. SIDE
2 21240P7W305 COVER, SIDE
3 21516P7W000 STAY A, TEMPERATURE SENSOR HARNESS (ATF)
4 21519P7W010 STAY, HARNESS HOLDER
5 21720P7W010 COVER, POSITION SENSOR
6 21812PGH020 GASKET, L. SIDE COVER
7 22710P7C000 PIPE A, FEED
8 22713PC9010 GUIDE A, FEED PIPE
9 22713PW4000 GUIDE A, FEED PIPE
10 22713PX4000 GUIDE A, FEED PIPE
11 22715P0Z000 PIPE B, FEED
12 22725P6H000 PIPE B, FEED
13 24282634000 BOLT, SHAFT FORK SETTING
14 24532PX4000 LEVER, PARKING BRAKE
15 24535P7Z000 SPRING, PARKING BRAKE
16 24539PA9003 STOPPER, PARKING BRAKE (3)
16 24537PA9003 STOPPER, PARKING BRAKE (1)
16 24538PA9003 STOPPER, PARKING BRAKE (2)
17 24552P0Z000 SPRING, PARKING PAWL
18 24553PN6000 ROLLER, PARKING BRAKE
19 24555PN6000 PIN, ROLLER (6MM)
20 24561PGH000 PAWL, PARKING BRAKE
21 24562PAX000 SHAFT, PARKING
22 27576PAX000 PISTON, TOP ACCUMULATOR
23 27583P7W000 SPRING A, THIRD ACCUMULATOR
24 27591P7W000 COVER, ACCUMULATOR (26MM)
25 28900P7W013 SENSOR ASSY., POSITION
25 28900P7W023 SENSOR, POSITION
26 90024612000 BOLT, SEALING (8MM)
27 90433639000 WASHER, LOCK (6MM)
28 90471580000 GASKET (8MM)
29 90602PX4000 CIRCLIP B, INNER (47MM)
30 90607P6H000 RING, SNAP (26MM)
31 90650P7W000 CLIP, WIRE HARNESS
32 90690P7W000 CLIP, CABLE (15MM)
33 90701639000 PIN, DOWEL (8X55)
34 91006P1B003 BEARING, BALL (9X20X6)
35 91201PA9004 OIL SEAL (9X18X7) (ARAI)
36 91301PC9003 Кольцо уплотнительное
37 91305PC9003 O-RING (34X1.9) (ARAI)
38 91305PX4003 O-RING (40X1.9) (NOK)
39 91311PA9004 O-RING (7.7X1.9) (NOK)
40 91314PC9004 O-RING (8.5X1.9) (NOK)
41 91314PW4003 O-RING (11X1.9) (NOK)
42 91331PC9003 O-RING (21.2X2.4) (ARAI)
43 91618SA5000 GROMMET B, CONTROL WIRE, 16MM
44 9,34031E+11 BOLT-WASHER (6X25)
45 9410106800 WASHER, PLAIN (6MM)
46 9420116120 PIN, SPLIT (1.6X12)
47 9452038000 CIRCLIP, INNER (38MM)
48 9,57011E+11 Болт 6X12
49 9,57011E+11 Болт (6X16)
50 9,57011E+11 BOLT, FLANGE (6X30)
51 9,57011E+11 BOLT, FLANGE (6X40)
52 9,57011E+11 BOLT, FLANGE (6X90)
    43.8 KB · Просмотры: 238
