Крышка головки блока цилиндров (2)
1 12030R70A00 GASKET SET, HEAD COVER
2 12050R70A00 GASKET SET, RR. HEAD COVER
3 12310RKG000 COVER ASSY., FR. CYLINDER HEAD
4 12315PLC000 BOLT, STUD
5 12316PLC000 WASHER
6 12316R70A00 COLLAR, PCV VALVE
7 12320R70A00 COVER, RR. CYLINDER HEAD
8 12341R70A00 GASKET, FR. HEAD COVER
9 12342P08004 SEAL, SPARK PLUG TUBE (NOK) (SUPERCEDED)
9 12342P2FA01 SEAL, SPARK PLUG TUBE (NOK) (SUPERCEDED)
9 12342RYE004 SEAL,SPARK PLUG T
10 12351R70A00 GASKET, RR. HEAD COVER
11 15610R70A00 CAP ASSY., OIL FILLER
12 15613PC6000 GASKET, OIL FILLER
12 15613R70A00 GASKET, OIL FILLER
13 15650RCAA02 GAUGE, OIL LEVEL
14 17130RYEA01 VALVE ASSY., PCV
15 30511R70A00 INSULATOR, FR. COIL HEAT
16 30512R70A00 INSULATOR, RR. COIL HEAT
17 90010P8AA00 BOLT A, HEAD COVER
18 90012P8AA00 BOLT B, HEAD COVER
19 90442P8AA00 WASHER, HEAD COVER
20 91307RCAA01 O-RING (10.2X1.8)
21 91308RCAA01 O-RING (14.8X1.8)
22 957010601408 BOLT, FLANGE (6X14)
23 957010602808 BOLT, FLANGE (6X28)
    39.4 KB · Просмотры: 222
