Корпус - аккумулятор
1 22743PW4000 PIPE (8X40)
2 22744PG4000 PIPE, TOP CLUTCH
3 22748P7Z000 PIPE (8X85)
4 27263PFL000 SEAT, VALVE SPRING
5 27551RDK000 VALVE, LOW HOLD ACCUMULATOR
6 27552RDK000 SPRING, LOW HOLD ACCUMULATOR
7 27561PAX000 PISTON, LOW ACCUMULATOR
8 27562RJB000 SPRING A, LOW ACCUMULATOR
9 27564RJB000 SPRING B, LOW ACCUMULATOR
10 27577RJB000 SPRING, FOURTH ACCUMULATOR
11 27581RDK000 SPRING, SECOND ACCUMULATOR
12 27587RJB010 SPRING A, REVERSE ACCUMULATOR
13 27588RJB010 SPRING B, REVERSE ACCUMULATOR
14 27591RJB000 COVER, ACCUMULATOR (26MM)
15 27812RJBE00 PLATE, ACCUMULATOR SEPARATOR
16 27860RJB010 BODY, ACCUMULATOR
17 28400RDK003 SOLENOID ASSY.
18 28500RJB004 SOLENOID ASSY.
19 90607P6H000 RING, SNAP (26MM)
20 91301P6H003 Кольцо уплотнительное (7,6X1,9)
21 91301P7Z004 O-RING (7.6X1.9) (DENSO)
22 91302P6H003 O-RING (9.6X1.9) (KEIHIN)
23 91302P7Z004 O-RING (9.6X1.9) (DENSO)
24 91331PC9003 O-RING (21.2X2.4) (ARAI)
25 9430108140 PIN, DOWEL (8X14)
26 9452028000 CIRCLIP, INNER (28MM)
27 957010602508 Болт
28 957010606008 BOLT, FLANGE (6X60)
29 957010608508 BOLT, FLANGE (6X85)
30 957010609508 BOLT, FLANGE (6X95)
31 957010611008 BOLT, FLANGE (6X110)
32 957010612508 BOLT, FLANGE (6X125)
    36.7 KB · Просмотры: 217
