Корпус-аккумулятор ('03-'06)
1 22743PW4000 PIPE (8X40)
2 22744PG4000 PIPE, TOP CLUTCH
3 22748P7Z000 PIPE (8X85)
4 27263PFL000 SEAT, VALVE SPRING
5 27551RDK000 VALVE, LOW HOLD ACCUMULATOR
6 27552RDK000 SPRING, LOW HOLD ACCUMULATOR
7 27561PAX000 PISTON, LOW ACCUMULATOR
8 27561RDK000 PISTON, LOW ACCUMULATOR
9 27562RDK000 SPRING A, LOW ACCUMULATOR
10 27564RDK000 SPRING B, LOW ACCUMULATOR
11 27577RDK000 SPRING, FOURTH ACCUMULATOR
12 27581RDK000 SPRING, SECOND ACCUMULATOR
13 27586RDK000 PISTON, REVERSE ACCUMULATOR
14 27587P7W000 SPRING A, REVERSE ACCUMULATOR
15 27588P7W000 SPRING B, REVERSE ACCUMULATOR
16 27591RDK000 COVER, ACCUMULATOR (26MM)
17 27812RDK000 PLATE, ACCUMULATOR SEPARATOR
18 27860RDK010 BODY, ACCUMULATOR
19 28400RDK003 SOLENOID ASSY.
20 28500RDK003 SOLENOID ASSY.
21 90606P7W000 RING, SNAP (36MM)
22 90607P6H000 RING, SNAP (26MM)
23 91301P7Z004 O-RING (7.6X1.9) (DENSO)
24 91302P7Z004 O-RING (9.6X1.9) (DENSO)
25 91321PF4004 O-RING (18.3X2.4) (NOK)
26 91331PC9003 O-RING (21.2X2.4) (ARAI)
27 91344PC9004 O-RING (29X2.4) (NOK)
28 9430108140 PIN, DOWEL (8X14)
29 9452028000 CIRCLIP, INNER (28MM)
30 957010602508 Болт
31 957010606008 BOLT, FLANGE (6X60)
32 957010608508 BOLT, FLANGE (6X85)
33 957010609508 BOLT, FLANGE (6X95)
34 957010611008 BOLT, FLANGE (6X110)
35 957010612508 BOLT, FLANGE (6X125)
36 957010614008 BOLT, FLANGE (6X140)
    37.6 KB · Просмотры: 222
