Компоненты переднего сиденья (L.)
1 81132STXA01 BRACKET, HARNESS
2 81193STXA01ZC COVER, FR. FOOT (OUTER) *YR292L*(BN BEIGE)
2 81193STXA01ZA COVER, FR. FOOT (OUTER) *NH167L*(GRAPHITE BLACK)
2 81193STXA01ZB COVER, FR. FOOT (OUTER) *NH557L*(MEDIUM GRAY)
3 81255SZ3A01 SWITCH ASSY., LUMBAR SUPPORT
4 81501STXA01ZB SOCK, L. HARNESS *NH556L*(GRAY)
4 81501STXA01ZC SOCK, L. HARNESS *YR240L*(LIGHT CREAM IVORY)
4 81501STXA01ZA SOCK, L. HARNESS *NH167L*(GRAPHITE BLACK)
4 81501STXA01ZD SOCK, L. HARNESS *YR351L*(BURGUNDY BROWN)
5 81502STXA01 PROTECTOR, L. EDGE
6 81510STXA01 DEVICE, L. FR. SEAT (8WAY)
7 81532STXA01 BRACKET, FLOOR CONNECTOR
9 81538STXA01 WIRE ASSY., L. FR. SEAT CUSHION ANCHOR
10 81539STXA01 PAN, L. CUSHION
11 81594STXA01ZB COVER, L. FR. FOOT (INNER) *NH557L*(MEDIUM GRAY)
11 81594STXA01ZC COVER, L. FR. FOOT (INNER) *YR292L*(BN BEIGE)
11 81594STXA01ZA COVER, L. FR. FOOT (INNER) *NH167L*(GRAPHITE BLACK)
12 81595STXA01ZB COVER, L. RR. FOOT (OUTER) *NH557L*(MEDIUM GRAY)
12 81595STXA01ZC COVER, L. RR. FOOT (OUTER) *YR292L*(BN BEIGE)
12 81595STXA01ZA COVER, L. RR. FOOT (OUTER) *NH167L*(GRAPHITE BLACK)
13 81596STXA01ZB COVER, L. RR. FOOT (INNER) *NH557L*(MEDIUM GRAY)
13 81596STXA01ZC COVER, L. RR. FOOT (INNER) *YR292L*(BN BEIGE)
13 81596STXA01ZA COVER, L. RR. FOOT (INNER) *NH167L*(GRAPHITE BLACK)
14 81606STXA00 CORD, L. POWER SEAT
15 81611S3VA01ZH KNOB, L. *NH556L*(GRAY)
15 81611S3VA01ZE KNOB, L. *YR240L*(LIGHT CREAM IVORY)
15 81611S3VA01ZA KNOB, L. *NH167L*(GRAPHITE BLACK)
15 81611S3VA01ZJ KNOB, L. *YR351L*(BURGUNDY BROWN)
16 81621STXA01ZC COVER, L. FR. SEAT HEIGHT (OUTER) *YR240L*(LIGHT CREAM IVORY)
16 81621STXA01ZA COVER, L. FR. SEAT HEIGHT (OUTER) *NH167L*(GRAPHITE BLACK)
16 81621STXA01ZD COVER, L. FR. SEAT HEIGHT (OUTER) *YR351L*(BURGUNDY BROWN)
16 81621STXA01ZB COVER, L. FR. SEAT HEIGHT (OUTER) *NH556L*(GRAY)
17 81622STXA01ZB COVER, L. FR. SEAT HEIGHT (INNER) *NH556L*(GRAY)
17 81622STXA01ZC COVER, L. FR. SEAT HEIGHT (INNER) *YR240L*(LIGHT CREAM IVORY)
17 81622STXA01ZA COVER, L. FR. SEAT HEIGHT (INNER) *NH167L*(GRAPHITE BLACK)
17 81622STXA01ZD COVER, L. FR. SEAT HEIGHT (INNER) *YR351L*(BURGUNDY BROWN)
18 81628STXA01 M.S.C. UNIT
19 81650S3VA01ZD SWITCH ASSY., L. POWER SEAT (8WAY) *NH556L*(GRAY)
19 81650S3VA01ZE SWITCH ASSY., L. POWER SEAT (8WAY) *YR240L*(LIGHT CREAM IVORY)
19 81650S3VA01ZA SWITCH ASSY., L. POWER SEAT (8WAY) *NH167L*(GRAPHITE BLACK)
19 81650S3VA01ZF SWITCH ASSY., L. POWER SEAT (8WAY) *YR351L*(BURGUNDY BROWN)
20 81651SDBA71ZK KNOB *NH556L* (A)(GRAY)
20 81651SDBA71ZE KNOB *YR240L* (A)(LIGHT CREAM IVORY)
20 81651SDBA71ZA KNOB *NH167L* (A)(GRAPHITE BLACK)
20 81651SDBA71ZQ KNOB *YR351L* (A)(BURGUNDY BROWN)
21 81652S3VA01ZD KNOB *NH556L* (B)(GRAY)
21 81652S3VA01ZE KNOB *YR240L* (B)(LIGHT CREAM IVORY)
21 81652S3VA01ZA KNOB *NH167L* (B)(GRAPHITE BLACK)
21 81652S3VA01ZF KNOB *YR351L* (B)(BURGUNDY BROWN)
22 81653SDBA71 SWITCH ASSY., L. (8WAY)
23 81679S0XA01 SENSOR ASSY., SEAT POSITION
24 90115S0XA01 SCREW, TORX (6X16)
25 90134SE3003 SCREW, TAPPING (5X10)
26 90135S7AJ51 BOLT-WASHER (10X25)
27 90143STX000 BOLT-WASHER (10X25)
28 90143ST5900 BOLT-WASHER (8X22)
29 90610SR3003 CLIP, GARNISH (KATO)
30 90650KV3000 BAND, WIRE
31 90667SA7003K4 CLIP, MAT (5MM) *YR240L*(LIGHT CREAM IVORY)
31 90667SA7003K8 CLIP, MAT (5MM) *NH556L*(GRAY)
31 90667SA7003YW CLIP, MAT (5MM) *NH167L*(GRAPHITE BLACK)
31 90667SA7003M2 CLIP, MAT (5MM) *YR351L*(BURGUNDY BROWN)
32 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
33 91533S04003 CLIP, CONNECTOR (NATURAL)
34 91533S82003 CLIP, CONNECTOR (BLACK)
35 91540S0A003 CLIP, HARNESS BAND (96.9MM) (NATURAL)
36 91541S0A003 CLIP, HARNESS BAND (145MM) (BLACK)
37 90134SE3003 SCREW, TAPPING (5X10)
38 9390314220 SCREW, TAPPING (4X10)
39 9405006080 Гайка (6 MM)
40 90667S0D003ZH Крепеж
40 90667S0D003A3 CLIP, TRIM (7MM) *YR351L*(BURGUNDY BROWN)
40 90667S0D003YD CLIP, TRIM (7MM) *NH556L*(GRAY)
40 90667S0D003YH CLIP, TRIM (7MM) *YR240L*(LIGHT CREAM IVORY)
41 81203STXA01 MOTOR, L. FR. HEIGHT
42 81204STXA01 MOTOR, L. RR. HEIGHT
43 81266STXA01 CABLE ASSY.
44 81271STXA01 PROTECTOR
45 81272STXA01 PROTECTOR B
46 81660STXA01 ADJUSTER ASSY., L. SLIDE (OUTER)
47 81670STXA01 ADJUSTER ASSY., L. SLIDE (INNER)
48 90150STXA01 SCREW
49 90350STXA01 NUT
50 90752STXA01 SPRING, HEIGHT PIN
    50.3 KB · Просмотры: 197
