Компоненты переднего сидения (L)
1 81132STXA01 BRACKET, HARNESS
2 81193STXA01ZB COVER, FR. FOOT (OUTER) NH557L: MEDIUM GRAY
2 81193STXA01ZC COVER, FR. FOOT (OUTER) YR292L: BEIGE
2 81193STXA01ZD COVER, FR. FOOT (OUTER) NH690L: PREMIUM BLACK
3 81255SZ3A01 SWITCH ASSY., LUMBAR SUPPORT
4 81501STXA01ZB SOCK, L. HARNESS (NA USE ALT: 81501-STX-A01ZA) NH556L: GRAY
4 81501STXA01ZC SOCK, L. HARNESS (NA USE ALT: 81501-STX-A01ZA) YR240L: LIGHT CREAM IVORY
5 81502STXA01 PROTECTOR, L. EDGE
6 81510STXL01 DEVICE, L. FR. SEAT (8WAY)
7 81532STXA01 BRACKET, FLOOR CONNECTOR
9 81538STXA01 WIRE ASSY., L. FR. SEAT CUSHION ANCHOR
10 81539STXA01 PAN, L. CUSHION
11 81594STXA01ZB COVER, L. FR. FOOT (INNER) NH557L: MEDIUM GRAY
11 81594STXA01ZC COVER, L. FR. FOOT (INNER) YR292L: BEIGE
11 81594STXA01ZD COVER, L. FR. FOOT (INNER) NH690L: PREMIUM BLACK
12 81595STXA01ZB COVER, L. RR. FOOT (OUTER) NH557L: MEDIUM GRAY
12 81595STXA01ZC COVER, L. RR. FOOT (OUTER) YR292L: BEIGE
12 81595STXA01ZD COVER, L. RR. FOOT (OUTER) NH690L: PREMIUM BLACK
13 81596STXA01ZB COVER, L. RR. FOOT (INNER) NH557L: MEDIUM GRAY
13 81596STXA01ZC COVER, L. RR. FOOT (INNER) YR292L: BEIGE
13 81596STXA01ZD COVER, L. RR. FOOT (INNER) NH690L: PREMIUM BLACK
14 81606STXL00 CORD, L. POWER SEAT (8WAY)
15 81611S3VA01ZE KNOB, L. YR240L: LIGHT CREAM IVORY
15 81611S3VA01ZH KNOB, L. NH556L: GRAY
15 81611S3VA01ZU KNOB, L. NH690L: PREMIUM BLACK
16 81621STXA01ZB COVER, L. FR. SEAT HEIGHT (OUTER) NH556L: GRAY
16 81621STXA01ZC COVER, L. FR. SEAT HEIGHT (OUTER) YR240L: LIGHT CREAM IVORY
16 81621STXA01ZE COVER, L. FR. SEAT HEIGHT (OUTER) NH690L: PREMIUM BLACK
17 81622STXA01ZB COVER, L. FR. SEAT HEIGHT (INNER) NH556L: GRAY
17 81622STXA01ZC COVER, L. FR. SEAT HEIGHT (INNER) YR240L: LIGHT CREAM IVORY
17 81622STXA01ZE COVER, L. FR. SEAT HEIGHT (INNER) NH690L: PREMIUM BLACK
18 81628STXA01 M.S.C. UNIT
19 81650S3VA01ZD SWITCH ASSY., L. POWER SEAT (8WAY) NH556L: GRAY
19 81650S3VA01ZE SWITCH ASSY., L. POWER SEAT (8WAY) YR240L: LIGHT CREAM IVORY
19 81650S3VA01ZK SWITCH ASSY., L. POWER SEAT (8WAY) NH690L: PREMIUM BLACK
20 81651SDBA71ZE KNOB (A) YR240L: LIGHT CREAM IVORY
20 81651SDBA71ZK KNOB (A) NH556L: GRAY
20 81651SDBA71ZY KNOB (A) NH690L: PREMIUM BLACK
21 81652S3VA01ZD KNOB (B) NH556L: GRAY
21 81652S3VA01ZE KNOB (B) YR240L: LIGHT CREAM IVORY
21 81652S3VA01ZK KNOB (B) NH690L: PREMIUM BLACK
22 81653SDBA71 SWITCH ASSY., L. (8WAY)
23 81679S0XA01 SENSOR ASSY., SEAT POSITION
24 90115S0XA01 SCREW, TORX (6X16)
25 90134SE3003 SCREW, TAPPING (5X10)
26 90135S7AJ51 BOLT-WASHER (10X25)
27 90143STX000 BOLT-WASHER (10X25)
28 90143ST5900 BOLT-WASHER (8X22)
29 90610SR3003 CLIP, GARNISH (KATO)
30 90650KV3000 BAND, WIRE
31 90667SA7003YG CLIP, MAT (5MM) NH120L: STAR BLACK
31 90667SA7003YW CLIP, MAT (5MM) NH167L: GRAPHITE BLACK
32 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
33 91533S04003 CLIP, CONNECTOR (NATURAL)
34 91533S82003 CLIP, CONNECTOR (BLACK)
35 91541S0A003 CLIP, HARNESS BAND (145MM) (BLACK)
36 91541S0A003 CLIP, HARNESS BAND (145MM) (BLACK)
37 90134SE3003 SCREW, TAPPING (5X10)
38 9390314220 SCREW, TAPPING (4X10)
39 9405006080 NUT, FLANGE (6MM)
40 90671S0D003ZF CLIP, ROOF (7MM) NH120L: STAR BLACK
41 81203STXA01 MOTOR, L. FR. HEIGHT (NOT AVAILABLE)
42 81204STXA01 MOTOR, L. RR. HEIGHT (NOT AVAILABLE)
43 81266STXA01 CABLE ASSY.
44 81271STXA01 PROTECTOR
45 81272STXA01 PROTECTOR B
46 81660STXA01 ADJUSTER ASSY., L. SLIDE (OUTER)
47 81670STXA01 ADJUSTER ASSY., L. SLIDE (INNER)
48 90150STXA01 SCREW
49 90350STXA01 NUT
50 90752STXL01 PIN, HEIGHT COIL
51 81102STXA01 PROTECTOR, R. EDGE
53 91501SZAA01 CLIP, ZIGZAG SPRING
55 90650STX003 BAND, CABLE
56 90651STX003 BAND, CABLE
    23.3 KB · Просмотры: 161
