Коленчатый вал - поршень
1 13010RKGE00 PISTON SET (STD)
2 13011RKGE02 RING SET, PISTON (STD)
3 13111P8AA00 PIN, PISTON
4 13115PRBA00 CLIP, PISTON PIN
5 13204P8AA01 BOLT, CONNECTING ROD
6 13210RK2A00 ROD, CONNECTING (NA USE ALT: 13210-RKG-000)
7 13211RYEA01 BEARING A, CONNECTING ROD (BLACK) (TAIHO)
7 13212RYEA01 BEARING B, CONNECTING ROD (BROWN) (TAIHO)
7 13213RYEA01 BEARING C, CONNECTING ROD (GREEN) (TAIHO)
7 13214RYEA01 BEARING D, CONNECTING ROD (YELLOW) (TAIHO)
7 13215RYEA01 BEARING E, CONNECTING ROD (PINK) (TAIHO)
8 13310RK2A01 CRANKSHAFT
9 13321RKG004 BEARING A, MAIN (UPPER) (BLACK) (TAIHO)
9 13322RKG004 BEARING B, MAIN (UPPER) (BROWN) (TAIHO)
9 13323RKG004 BEARING C, MAIN (UPPER) (GREEN) (TAIHO)
9 13324RKG004 BEARING D, MAIN (UPPER) (YELLOW) (TAIHO)
9 13325RKG004 BEARING E, MAIN (UPPER) (PINK)(TAIHO)
9 13326RKG004 BEARING F, MAIN (UPPER) (RED) (TAIHO)
10 13331P8AA01 WASHER, THRUST
11 13341RKG004 BEARING A, MAIN (LOWER) (BLACK) (TAIHO)
11 13342RKG004 BEARING B, MAIN (LOWER) (BROWN) (TAIHO)
11 13343RKG004 BEARING C, MAIN (LOWER) (GREEN) (TAIHO)
11 13344RKG004 BEARING D, MAIN (LOWER) (YELLOW) (TAIHO)
11 13345RKG004 BEARING E, MAIN (LOWER) (PINK)(TAIHO)
11 13346RKG004 BEARING F, MAIN (LOWER) (RED) (TAIHO)
12 13621RCAA11 PULLEY, TIMING BELT DRIVE
13 13622RJA000 PLATE, TIMING BELT GUIDE
14 13810R70A01 PULLEY, CRANKSHAFT
15 90017RJA003 BOLT-WASHER (16X49)
16 90704RCAA00 KEY (4.5X24)
17 13910R70A00 PLATE, CRANK PULSER
18 90013R70A01 BOLT, SPECIAL (8X11)
    30 KB · Просмотры: 191
