Картер коробки передач
1 21210RWE010 CASE, TRANSMISSION
2 21230RJFT00 CAP ASSY. A, L. SIDE
3 21232RWE000 HANGER A, TRANSMISSION
4 21233RWE000 HANGER B, TRANSMISSION
5 21234RWE000 STAY, MAIN GROUND
6 21251RJB000 CAP B, L. SIDE
7 21260RJFT00 CAP C, FEED PIPE
8 21396P20000 CAP, BREATHER
9 21811RDK000 GASKET, TORQUE CONVERTER CASE
10 22713PW4000 GUIDE A, FEED PIPE
11 22725RDK000 PIPE B, FEED
12 25614PK4000 BOLT, FILLER (ATF)
13 28450RJFT00 COVER, SOLENOID
14 28451RDK000 GASKET, SOLENOID COVER
15 90005RDK000 BOLT, SPECIAL (8X21)
16 90024612000 BOLT, SEALING (8MM)
17 90041PA5000 BOLT, STUD (6X28)
18 90081PE9000 BOLT, PLUG (20MM)
19 90380S5A000 BOLT, STUD (12X99.8)
20 90380S7S000 BOLT, STUD (12X49)
21 90441PK4000 Шайба уплотнительная (24 мм)
22 90472RDK010 SHIM L (65MM) (1.28)
22 90485RDK000 SHIM Y (65MM) (1.80)
22 90467RDK010 SHIM G (65MM) (1.08)
22 90498RDK000 SHIM AL (65MM) (2.32)
22 90479RDK010 SHIM S (65MM) (1.56)
22 90461RDK010 SHIM A (65MM) (0.84)
22 90492RDK000 SHIM AF (65MM) (2.08)
22 90473RDK010 SHIM M (65MM) (1.32)
22 90486RDK000 SHIM Z (65MM) (1.84)
22 90468RDK010 SHIM H (65MM) (1.12)
22 90480RDK010 SHIM T (65MM) (1.60)
22 90462RDK010 SHIM B (65MM) (0.88)
22 90493RDK000 SHIM AG (65MM) (2.12)
22 90474RDK010 SHIM N (65MM) (1.36)
22 90487RDK000 SHIM AA (65MM) (1.88)
22 90469RDK010 SHIM I (65MM) (1.16)
22 90481RDK000 SHIM U (65MM) (1.64)
22 90463RDK010 SHIM C (65MM) (0.92)
22 90494RDK000 SHIM AH (65MM) (2.16)
22 90475RDK010 SHIM O (65MM) (1.40)
22 90488RDK000 SHIM AB (65MM) (1.92)
22 90470RDK010 SHIM J (65MM) (1.20)
22 90482RDK000 SHIM V (65MM) (1.68)
22 90464RDK010 SHIM D (65MM) (0.96)
22 90495RDK000 SHIM AI (65MM) (2.20)
22 90476RDK010 SHIM P (65MM) (1.44)
22 90489RDK000 SHIM AC (65MM) (1.96)
22 90483RDK000 SHIM W (65MM) (1.72)
22 90465RDK010 SHIM E (65MM) (1.00)
22 90496RDK000 SHIM AJ (65MM) (2.24)
22 90477RDK010 SHIM Q (65MM) (1.48)
22 90490RDK000 SHIM AD (65MM) (2.00)
22 90471RDK010 SHIM K (65MM) (1.24)
22 90484RDK000 SHIM X (65MM) (1.76)
22 90466RDK010 SHIM F (65MM) (1.04)
22 90497RDK000 SHIM AK (65MM) (2.28)
22 90478RDK010 SHIM R (65MM) (1.52)
22 90460RDK000 SHIM 0A (65MM) (0.80)
22 90491RDK000 SHIM AE (65MM) (2.04)
23 90471580000 GASKET (8MM)
24 90602RDK000 CIRCLIP, INNER (40MM)
25 90615P0Z000 RING, SNAP (82MM)
26 91002RJFT01 BEARING, BALL (29X82X15/19.5)
27 91006RJF005 BEARING, BALL (9X20X6)
28 91010RJF005 BEARING, BALL (12X24X6)
29 91011RJFT01 BEARING, BALL (20X41X17.5)
30 91205P0X005 Сальник коробки передач (40X56X9)
31 91302RDK003 O-RING (28X2.2) (NOK)
32 91303PC9004 O-RING (104X2.2) (NOK)
33 91304RDK003 O-RING (43.5X2.2) (NOK)
34 91305PC9003 O-RING (34X1.9) (ARAI)
35 91314PW4003 O-RING (11X1.9) (NOK)
36 9410920000 Шайба уплотнительная сливного/заливного отверстия заднего редуктора, заливного отверстия МКПП (20mm)
37 9430108140 PIN, DOWEL (8X14)
38 957010602008 BOLT, FLANGE (6X20)
39 957010603508 BOLT, FLANGE (6X35)
40 957010802008 Болт
41 957011005008 BOLT, FLANGE (10X50)
42 957011007008 BOLT, FLANGE (10X70)
43 957011008008 BOLT, FLANGE (10X80)
44 957011009008 BOLT, FLANGE (10X90)
45 957011010008 BOLT, FLANGE (10X100)
46 957011011008 BOLT, FLANGE (10X110)
47 957011013008 BOLT, FLANGE (10X130)
48 957011211008 Болт
    47.5 KB · Просмотры: 254
