Задняя головка блока цилиндров (2)
1 12204PJ7305 GUIDE, VALVE (OVER SIZE)
2 12205PJ7305 GUIDE, EX. VALVE (OVER SIZE)
3 12207PC6300 WASHER, SEALING (16MM)
4 12207634300 WASHER, SEALING BOLT
5 12208P8CA01 BOLT, SEALING (28MM)
6 12210PZ1004 SEAL A, VALVE STEM (NOK)
7 12211PZ1004 SEAL B, VALVE STEM (NOK)
8 12240RDVJ00 COVER ASSY., RR. CAMSHAFT THRUST
9 12251RKG004 GASKET, CYLINDER HEAD
10 12300R70810 CYLINDER HEAD ASSY., RR. (DOT)
11 12432R72A01 BRIDGE, ROCKER SHAFT
12 12434R72A00 HOLDER ASSY., RR. ROCKER SHAFT
13 14820RKG003 MOTION, LOST
14 32746R70A00 STAY F, ENGINE HARNESS
15 36161RN0A00 STAY, PURGE JOINT
16 90004PE2005 BOLT, SEALING (10MM)
17 90005PAAA01 BOLT-WASHER (12X163)
18 90026P8AA00 BOLT, STUD (8X41)
19 90083PG1000 BOLT, SEALING (16MM)
20 90401PE2003 WASHER, SEALING (10MM)
21 90705PT0000 PIN, DOWEL (16X22)
22 91301P8AA00 O-RING (48.5X2.4)
23 92900060121B BOLT, STUD (6X12)
24 92900080251B BOLT, STUD (8X25)
25 92900080321B BOLT, STUD (8X32)
26 9405006080 NUT, FLANGE (6MM)
27 9430108100 PIN, DOWEL (8X10)
28 9430110120 PIN, DOWEL (10X12)
29 957010801608 BOLT, FLANGE (8X16)
30 957010802808 BOLT, FLANGE (8X28)
31 957010804008 BOLT, FLANGE (8X40)
32 958010806008 BOLT, FLANGE (8X60)
    36.9 KB · Просмотры: 190
