Задний дифференциал
Задний дифференциал
1 29421RDK000 CLAMP, BREATHER TUBE
2 41130RYGA00 TUBE ASSY., BREATHER
3 41200RWG080 CARRIER ASSY., RR. DIFFERENTIAL (MSDS)
4 41930RDL003 BODY ASSY., BREATHER END
5 41931P6R000 JOINT, BREATHER TUBE
6 41931RDL003 JOINT, BREATHER TUBE
7 41932RYG003 GROMMET, BREATHER JOINT
8 41933RDL013 BOX, BREATHER
9 41934RYGA01 CLIP, BREATHER BOX
10 41935RDL003 BODY, BREATHER END
11 41936PNZ013 CLAMP, BREATHER
12 41936RYGA01 CLAMP, BREATHER TUBE
13 41937RYG000 TUBE B, BREATHER
15 48160RWG003 SENSOR ASSY., TEMPERATURE (ATF)
16 48321RWG000 STAY A, RR. DIFFERENTIAL CABLE
17 48324RWG000 STAY D, RR. DIFFERENTIAL CABLE
18 48326RWG000 COVER, TEMPERATURE SENSOR (ATF)
21 50740STXA51 RUBBER, L. RR. DIFFERENTIAL MOUNTING
22 90081PVH003 BOLT, PLUG (18MM)
23 90081PWT000 BOLT, DRAIN PLUG (20MM)
24 90162STXA00 BOLT, FLANGE (14X95)
25 90163STXA00 BOLT, FLANGE (14X59)
26 90402RJC000 WASHER, THRUST AXLE
27 90471PX4000 WASHER, DRAIN PLUG (18MM)
28 91205RWG003 OIL SEAL (34.7X54X9)
29 91206RWG003 DUST SEAL (40X55X7.5)
30 91303RAY003 O-RING (12X2.4) (NOK)
31 91540S30003 CLIP, HARNESS BAND (151.5MM) (NATURAL)
32 9410920000 WASHER, DRAIN PLUG (20MM)
33 950055500320M BULK HOSE, VACUUM (5.5X3000) OEM CUT SIZE: (5.3X90)
34 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X485)
34 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X440)
34 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X190)
34 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X160)
35 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X160)
35 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X190)
35 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X440)
35 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X485)
36 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X485)
36 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X440)
36 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X190)
36 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X160)
37 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X160)
37 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X190)
37 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X440)
37 950054500120M BULK HOSE, VACUUM (4.5X1000) OEM CUT SIZE: (4.5X485)
38 957010601208 BOLT, FLANGE (6X12)
39 957010601608 BOLT, FLANGE (6X16)
41 91507PT3A01 BAND, WIRE HARNESS (90.4MM) (BLACK)
42 50710TK5A51 RUBBER, R. RR. DIFFERENTIAL MOUNTING (FR)
43 50720TK5A51 RUBBER, L. RR. DIFFERENTIAL MOUNTING (FR)
44 957011002508 BOLT, FLANGE (10X25)
    20.6 KB · Просмотры: 192
