Задний водяной шланг
1 79326S0XA11 BRACKET E, HEATER PIPE
2 79327S0XA01 BRACKET F, HEATER PIPE
3 79328S0XA01 BRACKET G, HEATER PIPE
4 79731S0XA00 GROMMET, HEATER PIPE
5 79742STXA01 BRACKET D, HEATER PIPE
6 79753SHJA01 CLIP A
7 79771STXA00 HOSE, RR. WATER INLET
8 79776STXA00 HOSE, RR. WATER OUTLET
9 79791STXA01 PIPE
10 79792STXA01 PIPE
11 90129S0XA01 NUT
12 90361SV4003 NUT, PAINT CUTTING (6MM)
13 90663SB2003 GROMMET, SCREW (6MM)
14 19513PE0003 CLAMP, WATER HOSE (21.7MM) (CHUO HATSUJO)
15 91901S0XA00 SCREW, PAN (4X8)
16 92301050160H BOLT, RECESSED (5X16)
17 934050601604 Болт (6X16)
18 9390426220 SCREW, TAPPING (6X16)
19 9410105400 Шайба, 5MM
20 9411105400 WASHER, SPRING (5MM)
    16.8 KB · Просмотры: 230
