Дифференциал
Дифференциал
1 29011RWE000 GEAR, TRANSFER DRIVE
2 29021RJFT00 SHAFT, TRANSFER DRIVEN GEAR
3 29041RDK000 SHIM K (28.5MM) (2.02)
3 29054RDK000 SHIM X (28.5MM) (2.28)
3 29035RDK000 SHIM E (28.5MM) (1.90)
3 29048RDK000 SHIM R (28.5MM) (2.16)
3 29042RDK000 SHIM L (28.5MM) (2.04)
3 29055RDK000 SHIM Y (28.5MM) (2.30)
3 29036RDK000 SHIM F (28.5MM) (1.92)
3 29049RDK000 SHIM S (28.5MM) (2.18)
3 29043RDK000 SHIM M (28.5MM) (2.06)
3 29056RDK000 SHIM Z (28.5MM) (2.32)
3 29037RDK000 SHIM G (28.5MM) (1.94)
3 29050RDK000 SHIM T (28.5MM) (2.20)
3 29031RDK000 SHIM A (28.5MM) (1.82)
3 29044RDK000 SHIM N (28.5MM) (2.08)
3 29057RDK000 SHIM AA (28.5MM) (2.34)
3 29038RDK000 SHIM H (28.5MM) (1.96)
3 29051RDK000 SHIM U (28.5MM) (2.22)
3 29032RDK000 SHIM B (28.5MM) (1.84)
3 29045RDK000 SHIM O (28.5MM) (2.10)
3 29039RDK000 SHIM I (28.5MM) (1.98)
3 29052RDK000 SHIM V (28.5MM) (2.24)
3 29033RDK000 SHIM C (28.5MM) (1.86)
3 29046RDK000 SHIM P (28.5MM) (2.12)
3 29040RDK000 SHIM J (28.5MM) (2.00)
3 29053RDK000 SHIM W (28.5MM) (2.26)
3 29034RDK000 SHIM D (28.5MM) (1.88)
3 29047RDK000 SHIM Q (28.5MM) (2.14)
4 41100RYF000 DIFFERENTIAL ASSY.
5 41233RWE000 GEAR, FINAL DRIVEN
6 41381RJFT00 SPACER (46X87X1)
7 41382RDK000 SPACER (46X85X1)
8 41451RGR000 SHIM L (85MM) (1.625)
8 41464RGR000 SHIM Y (85MM) (1.950)
8 41445RGR000 SHIM F (85MM) (1.475)
8 41477RGR000 SHIM AL (85MM) (2.275)
8 41458RGR000 SHIM S (85MM) (1.800)
8 41471RGR000 SHIM AF (85MM) (2.125)
8 41452RGR000 SHIM M (85MM) (1.650)
8 41465RGR000 SHIM Z (85MM) (1.975)
8 41446RGR000 SHIM G (85MM) (1.500)
8 41478RGR000 SHIM AM (85MM) (2.300)
8 41459RGR000 SHIM T (85MM) (1.825)
8 41440RGR000 SHIM A (85MM) (1.350)
8 41472RGR000 SHIM AG (85MM) (2.150)
8 41453RGR000 SHIM N (85MM) (1.675)
8 41466RGR000 SHIM AA (85MM) (2.000)
8 41447RGR000 SHIM H (85MM) (1.525)
8 41479RGR000 SHIM AN (85MM) (2.325)
8 41460RGR000 SHIM U (85MM) (1.850)
8 41441RGR000 SHIM B (85MM) (1.375)
8 41473RGR000 SHIM AH (85MM) (2.175)
8 41454RGR000 SHIM O (85MM) (1.700)
8 41467RGR000 SHIM AB (85MM) (2.025)
8 41448RGR000 SHIM I (85MM) (1.550)
8 41480RGR000 SHIM AO (85MM) (2.350)
8 41461RGR000 SHIM V (85MM) (1.875)
8 41442RGR000 SHIM C (85MM) (1.400)
8 41474RGR000 SHIM AI (85MM) (2.200)
8 41455RGR000 SHIM P (85MM) (1.725)
8 41468RGR000 SHIM AC (85MM) (2.050)
8 41449RGR000 SHIM J (85MM) (1.575)
8 41462RGR000 SHIM W (85MM) (1.900)
8 41443RGR000 SHIM D (85MM) (1.425)
8 41475RGR000 SHIM AJ (85MM) (2.225)
8 41456RGR000 SHIM Q (85MM) (1.750)
8 41469RGR000 SHIM AD (85MM) (2.075)
8 41450RGR000 SHIM K (85MM) (1.600)
8 41463RGR000 SHIM X (85MM) (1.925)
8 41444RGR000 SHIM E (85MM) (1.450)
8 41476RGR000 SHIM AK (85MM) (2.250)
8 41457RGR000 SHIM R (85MM) (1.775)
8 41470RGR000 SHIM AE (85MM) (2.100)
9 90003RWE000 BOLT, SPECIAL (11MM)
10 91008RJFT12 BEARING, ANGULAR (22X67X19)
11 91009RJFT01 BEARING, BALL (40X80X16.5)
12 91120RJFT01 BEARING, TAPER (45X87X24.75)
13 91122RJFT02 BEARING, TAPER (45X85X24.7)
    21.1 KB · Просмотры: 198
