Дифференциал ('01-'02)
1 29011PGV000 GEAR, TRANSFER DRIVE
2 29021PGV000 SHAFT, TRANSFER DRIVEN GEAR
3 29037PGV000 SHIM G (24MM) (2.097)
3 29031PGV000 SHIM A (24MM) (1.719)
3 29038PGV000 SHIM H (24MM) (2.160)
3 29032PGV000 SHIM B (24MM) (1.782)
3 29039PGV000 SHIM J (24MM) (2.223)
3 29033PGV000 SHIM C (24MM) (1.845)
3 29034PGV000 SHIM D (24MM) (1.908)
3 29035PGV000 SHIM E (24MM) (1.971)
3 29036PGV000 SHIM F (24MM) (2.034)
4 41100PGH010 DIFFERENTIAL ASSY.
5 41233PGH000 GEAR, FINAL DRIVEN
6 41381P7T000 SPACER (46X80X1)
7 41382P7T000 SPACER (46X81X1)
8 41440PGH000 SHIM C (81MM) (2.175)
8 41456PGH000 SHIM S (81MM) (2.975)
8 41447P7T000 SHIM J (81MM) (2.50)
8 41453PGH000 SHIM P (81MM) (2.825)
8 41444P7T000 SHIM G (81MM) (2.35)
8 41450PGH000 SHIM M (81MM) (2.675)
8 41441P7T000 SHIM D (81MM) (2.20)
8 41457P7T000 SHIM T (81MM) (3.00)
8 41447PGH000 SHIM J (81MM) (2.525)
8 41438P7T000 SHIM A (81MM) (2.05)
8 41454P7T000 SHIM Q (81MM) (2.85)
8 41444PGH000 SHIM G (81MM) (2.375)
8 41451P7T000 SHIM N (81MM) (2.70)
8 41441PGH000 SHIM D (81MM) (2.225)
8 41457PGH000 SHIM T (81MM) (3.025)
8 41448P7T000 SHIM K (81MM) (2.55)
8 41438PGH000 SHIM A (81MM) (2.075)
8 41454PGH000 SHIM Q (81MM) (2.875)
8 41445P7T000 SHIM H (81MM) (2.40)
8 41451PGH000 SHIM N (81MM) (2.725)
8 41442P7T000 SHIM E (81MM) (2.25)
8 41458P7T000 SHIM U (81MM) (3.05)
8 41448PGH000 SHIM K (81MM) (2.575)
8 41439P7T000 SHIM B (81MM) (2.10)
8 41455P7T000 SHIM R (81MM) (2.90)
8 41445PGH000 SHIM H (81MM) (2.425)
8 41452P7T000 SHIM O (81MM) (2.75)
8 41442PGH000 SHIM E (81MM) (2.275)
8 41449P7T000 SHIM L (81MM) (2.60)
8 41439PGH000 SHIM B (81MM) (2.125)
8 41455PGH000 SHIM R (81MM) (2.925)
8 41446P7T000 SHIM I (81MM) (2.45)
8 41452PGH000 SHIM O (81MM) (2.775)
8 41443P7T000 SHIM F (81MM) (2.30)
8 41449PGH000 SHIM L (81MM) (2.625)
8 41440P7T000 SHIM C (81MM) (2.15)
8 41456P7T000 SHIM S (81MM) (2.95)
8 41446PGH000 SHIM I (81MM) (2.475)
8 41453P7T000 SHIM P (81MM) (2.80)
8 41443PGH000 SHIM F (81MM) (2.325)
8 41450P7T000 SHIM M (81MM) (2.65)
9 90003PGV000 BOLT, SPECIAL (10X35)
10 91007PGV003 BEARING, ANGULAR (35X72X28)
11 91008PGV003 BEARING, ANGULAR (24X72X18)
12 91121P7T305 BEARING, SPECIAL TAPER (45X80X19.75)
13 91124PGH305 BEARING, TAPER (45X81X16)
