Главный корпус-аккумулятор ('01-'02)
1 22743PG4000 PIPE, THIRD CLUTCH
2 22748PW4000 PIPE (8X62)
3 27122P6H000 CAP (12MM)
4 27263P1V000 SEAT, VALVE SPRING
5 27524P6H000 CLIP, CAP
6 27573P7W000 PISTON, LOW HOLD ACCUMULATOR
7 27576PAX000 PISTON, TOP ACCUMULATOR
8 27577P7W000 SPRING, THIRD ACCUMULATOR
9 27586P7W000 PISTON, REVERSE ACCUMULATOR
10 27587P7W000 SPRING A, REVERSE ACCUMULATOR
11 27588P7W000 SPRING B, REVERSE ACCUMULATOR
12 27700P7W000 BODY ASSY., TOP ACCUMULATOR
13 27712P7W000 PLATE, TOP ACCUMULATOR SEPARATOR
14 90003PP6000 BOLT, FLANGE (6X150)
15 90606P7W000 RING, SNAP (36MM)
16 90607P6H000 RING, SNAP (26MM)
17 91321PF4004 O-RING (18.3X2.4) (NOK)
18 91331PC9003 O-RING (21.2X2.4) (ARAI)
19 91331PL5J00 O-RING (20.2X2.4) (NOK)
20 91344PC9004 O-RING (29X2.4) (NOK)
21 9430108140 PIN, DOWEL (8X14)
22 957010604008 BOLT, FLANGE (6X40)
23 957010605008 BOLT, FLANGE (6X50)
24 957010608008 BOLT, FLANGE (6X80)
25 957010609008 BOLT, FLANGE (6X90)
26 957010610008 BOLT, FLANGE (6X100)
    27 KB · Просмотры: 216
