Вторичный вал ('03-'06)
1 22814PRP003 RING, SEALING (29MM)
2 23230RDK030 SHAFT, SECONDARY
4 23418RDK000 HUB, CLUTCH (L-H)
6 23430RDK030 GEAR, SECONDARY SHAFT SECOND
7 23495RDK000 GEAR, SECONDARY SHAFT IDLE
8 90201RDK000 NUT, FLANGE (26MM)
9 90402RDK000 WASHER (29X40X3.9)
10 90443RDK000 COLLAR (32X39X63.3)
11 90506RDK000 WASHER E (52MM) (2.505)
11 90513RDK000 WASHER L (52MM) (2.430)
11 90502RDK000 WASHER A (52MM) (2.405)
11 90509RDK010 WASHER H (52MM) (2.530)
11 90503RDK010 WASHER B (52MM) (2.680)
11 90506RDK010 WASHER E (52MM) (2.605)
11 90514RDK000 WASHER M (52MM) (2.405)
11 90502RDK010 WASHER A (52MM) (2.705)
11 90510RDK000 WASHER I (52MM) (2.605)
11 90507RDK000 WASHER F (52MM) (2.530)
11 90504RDK000 WASHER C (52MM) (2.455)
11 90510RDK010 WASHER I (52MM) (2.505)
11 90507RDK010 WASHER F (52MM) (2.580)
11 90504RDK010 WASHER C (52MM) (2.655)
11 90511RDK000 WASHER J (52MM) (2.630)
11 90508RDK000 WASHER G (52MM) (2.555)
11 90505RDK000 WASHER D (52MM) (2.480)
11 90511RDK010 WASHER J (52MM) (2.480)
11 90508RDK010 WASHER G (52MM) (2.555)
11 90505RDK010 WASHER D (52MM) (2.630)
11 90512RDK000 WASHER K (52MM) (2.455)
11 90509RDK000 WASHER H (52MM) (2.580)
12 90621RDK000 RING, SNAP (32MM)
13 91005RDK003 Подшипник
14 91018RDK003 BEARING, NEEDLE (43.5X61.5X2.5)
15 91021RDK013 BEARING, NEEDLE (44X50X42)
16 91022RDK013 BEARING, NEEDLE (39X44X47)
17 91032RDK023 NEEDLE, THRUST (44X66X3.5)
18 91039RDK005 NEEDLE, THRUST (46X62.95X4.62)(NSK)
19 91040RDK003 NEEDLE, THRUST (40X57X2.5)
20 91307PA9003 O-RING (31.2X1.9) (ARAI)
21 91326P4V004 O-RING (26.7X1.9)
22 23411RDK305 GEAR SET, SECONDARY SHAFT LOW
    27.6 KB · Просмотры: 216
