Вторичный вал ('01-'02)
1 22816P6H003 RING, SEAL (35MM)
2 23230P7W000 SHAFT, SECONDARY
2 23230RAY000 SHAFT, SECONDARY
3 23411P7W000 GEAR, SECONDARY SHAFT LOW
4 23418P7W000 HUB, CLUTCH (L-H)
5 23420RAY005 HUB, SECONDARY SHAFT LOWCLUTCH
6 23431RAYA00 GEAR, SECONDARY SHAFT SECOND
6 23431RDG000 GEAR, SECONDARY SHAFT SECOND
7 23495P7W000 GEAR, SECONDARY IDLE
8 90203P0Z000 NUT, FLANGE (24MM) (LEFT HAND THREAD)
9 90402P0Z000 WASHER, SPRING (24MM)
10 90409P0Z000 WASHER, THRUST (37X55X5.05)
10 90410P0Z000 WASHER, THRUST (37X55X5.10)
10 90411P0Z000 WASHER, THRUST (37X55X5.15)
10 90412P0Z000 WASHER, THRUST (37X55X5.20)
10 90406P0Z000 WASHER, THRUST (37X55X4.90)
10 90407P0Z000 WASHER, THRUST (37X55X4.95)
10 90408P0Z000 WASHER, THRUST (37X55X5.00)
11 90431P0Z000 COTTER (32MM)
12 90432P0Z000 RETAINER, COTTER
13 90502P0Z000 WASHER, SPLINE (38X56.5X6.85)
13 90503P0Z000 WASHER, SPLINE (38X56.5X6.90)
13 90504P0Z000 WASHER, SPLINE (38X56.5X6.95)
13 90505P0Z000 WASHER, SPLINE (38X56.5X7.00)
13 90506P0Z000 WASHER, SPLINE (38X56.5X7.05)
13 90507P0Z000 WASHER, SPLINE (38X56.5X7.10)
14 91005P7Z003 BEARING, BALL (65X88.5X10)
15 91011P7W003 BEARING, NEEDLE (34X40X20)
16 91012P7W003 BEARING, NEEDLE (38X44X20)
17 91019P7Z003 BEARING, THRUST NEEDLE (38X57X2.5)
18 91023P7T013 BEARING, THRUST NEEDLE (34X55.5X2.5)
19 91316PR9003 O-RING (33X1.9) (ARAI)
20 9451035000 CIRCLIP, OUTER (35MM)
